JARE77
Everything posted by JARE77
  1. Cool I just picked up a set of rezzies for my Works tripple rates and I had the same questions! Thats exactly the information I needed thanx!
  2. ^^^ Exactly what Loco said!
  3. I run IPONE strawberry scented stuff. It is a very good oil,I have seen the inside of many motors that run it and its really amazing to see how well it lubricates the internals! Plus when mixed with Klotz 110 it smells like none other Anyone else ever used this oil?
  4. I have seen many like that they are usually considered a 370 long rod. But actually the rods are not longer the pistons are just shorter. I think they do require a spacer like doubled up gaskets or something.
  5. OOOK then! Thats a little out of the ordinary
  6. Definitly a good investment! You will thank yourself next time you tear everything down!
  7. Turf tamers or Kenda Klaws are both good choices.
  8. They dont like water! You have to be very carefull when washing that you keep water away from the carbs, airbox,and intake areas. You should also use a little premix in a spray bottle rather than using starting fluid.
  9. I run mine year round and have never had any trouble at all with them! The first couple rides with them made me nervous but now 2 years later they have definitly proven to be reliable.
  10. Good job man! They turned out great.
  11. There arent to many bikes that can out climb a banshee
  12. The sprocket hub will fit but the axle hubs wont because the x-33 is a pin drive unit. The lonestar axle hubs should fit on the other durable axles Because they are still stock spline pattern I believe.
  13. Thats funny stuff!
  14. Thats friggin neat! Good luck with the project
  15. Hey Meathead you got any recent pics of the bike? I think its possibly the nicest shee I have ever seen I think I miss it,its been soo long since we seen pics of it!
  16. I know guys with both Line-x and Rhino liners,The line-x are far supperior in my opinion and they even look nicer I think anyway.
  17. My 95 came with yella springs.
  18. Right on That looks great! Good job!
  19. They do look the same as stockers,But I thought they were usually white? Could be like a factory replacement type. They are definatly a single stage reed!
  20. I wish my stocker would break or something so I can convince the ol' lady I need a pingle. They are sweet for sure!
  21. If you take the water pump cover off you should be able to tell if its coming from there a little better if you havent done that already. If you think it is just drain your coolant and open it up its pretty basic stuff. If you have a clymers manual it will guide you through everything,if you dont have one I highly recomend getting one. Its like the Banshee bible!
  22. Probably just burt packing flying out Hopefully!
  23. Dont the long travel arms usually require 18 or 19" inchers? Ideally.
  24. I know reving the piss out of it and letting right off is really hard on it but, Maybe it was something else like an air leak caused likely from the previous crash. I dont know ,just a thought.
