it's stolen
Everything posted by it's stolen
  1. yes you will need to rejet. probably 3 to 5 jet sizes smaller.
  2. KP is on my list of places to go this summer. but I will be in St. A's from 7/13 to 7/18
  3. yes it will fail. both of mine did. my 97 failed when it was 18 months old. my 94 failed last week. RMATV has a new one for 170 dollars but you need to buy regulator also and that is 20 bucks. when they go bad they will not give any warning the shee just stops running.
  4. when itunes is open you can click on the playlist button to view all the songs on the play list. if you want to remove one song, yoou can right click the song and then select delete.
  5. your ipod must be hooked to your computer to remove songs.
  6. I dont drive that much. mostly fix the trucks and buses. sometimes i have to drive the tow truck to pick up dead buses. i had to get a hazmat endorsment to drive the service truck and the 10 wheelers. I hate dealing with the tsa. i work at an airport so i deal with them every day.
  7. I never win anything. but put me in anyway.
  8. I was in st. anthony this weekend. I heard about jeremy on friday.
  9. my 77 camaro had 160 hp. I think most of the car 350s were all the same engine.
  10. I just checked alldata and p1404 is a stuck egr valve. the valve may be dirty or may need to be replaced. most of the time they are bad and need to be replaced.
  11. I wont be there untill 7/14 thru 7/18
  12. did you check where the shift fork rides in the shift drum. 1/16 of an inch of wear can cause what you are discribing. my brothers kawi did the samething. a shift drum and fork fixed it like new.
  13. I also had a very good transaction with gipperz
  14. the WR crank has a 2mm longer stroke. It is amazing what a 2mm longer stroke and a 2mm larger bore will do for the older 450s
  15. my brother has a yoshamira pipe, pro flow plate with a k&n, hot cams and aftermarket ignition. I dont remember what brand the cdi is. we have installed a WR crank, 2mm big bore and he has had the head ported. it runs really good but i hear the ron woods pipe would make more power
  16. the kicker is in good condition. it is off a 93, it was removed in 98 and has been sitting on a shelf for 8 years. $35.00 shipped.
  17. I have a kicker but my caliper is no good.
  18. what kind of work do you need done?
  19. the tenth digit of the vin is the year 5 = 2005
  20. I would like to go but I dont want to take my 3 year old with that many people around and i cant leave him home.
  21. it is a 95 but I dont know the model
  22. I put an rd 250 motor in a blaster frameand I used all the wiring fron the bike. I think the 350 will bolt into the banshee and then you can just use the bike wire harness. you will have to modify the end of the pipes where they go on the motor.
  23. pm boonman
