badbonz
    02 Banshee, Toomey T5 pipes, 2-1 air kit, V-Force Reeds, boot bottle, cool head.
badbonz's Achievements
  1. To reply to my own question....ive done some research and synthetic oils in the tranny do in fact cause slipping which leads to the question that was posted earlier. Synthetics are suppose to be the best...hmmmm. Anyway, apparently Amsoil is the worst for slipping clutches. Thanks to all for your answers. Bonz
  2. Thanks for your answer. I apologize if this is a repeat thank you..my computer is acting funny. Which motul tranny oil are you using? Thanks
  3. Howdy! With all the oils out there on the market and getting confused as to which ones to use, I figured I would ask the members. What tranny oil would you recommend and or use for a slightly modified banshee? As long as we are on the oils, what premix oil would you recommend and or use? Thanks, Bonz
  4. Howdy! With all the oils out there on the market and getting confused as to which ones to use, I figured I would ask the members. What tranny oil would you recommend and or use for a slightly modified banshee? As long as we are on the oils, what premix oil would you recommend and or use? Thanks, Bonz
  5. Im lookin to put a single carb on my Banshee and would like some help from the members. Any suggestions on size and type? Based on those questions, will I have to do any modifications to the motor itself? Thanks and any help will HELP! badbonz
  6. Howdy! Im lookin to put a single carb on my Banshee and would like some help from the members. Any suggestions on size and type? Based on those questions, will I have to do any modifications to the motor itself? Thanks and any help will HELP! badbonz
  7. Duh...thanks, I figured it out.
  8. Thanks but what is the site for Meats?
  9. Thanks for the info!
  10. Howdy All! Im planning on running a Dyna ignition on my Banshee and am wondering if I need to run a timing plate as well or will the Dyna take care if it all. Any suggestions? Badbonz
  11. Howdy all! Im thinking of punching out my stock cylinders to the next size up. Will I be able to use my cool heads after doing this or will I have to go an alternate route. After doing some research, I wish I would have bought some Noss heads. For now, I have these. Also, I was talking to a machine shop near me about porting and polishing. He suggested not doing this because you want turbulance so it atomizes the fuel better. Any suggestions on this or thoughts? Badbonz
  12. Thanks!!!!
  13. Sandman....I was in a little race with a stock 450 at our local Sand Mountain in NV. My Banshee is slightly modified to where I consider it fast...... The 450 almost whooped me! They are dang fast and dang expensive! Good luck!
  14. Howdy! Someone told me of another site like this one and I cant remember the name of it. I do know that it started with Blue....??? I visited it once before and remember that it dealt with Yamahas. Does anybody know the site?? Thanks, badbonz
