Big Blue
Everything posted by Big Blue
  1. Get the 2:1 kit then, and you could even get your cylinders ported for low end also.
  2. All depends on if you want more low end or not.
  3. Ive seen a set that wasnt cleaned up and you wouldnt be able to run them. You should be able to see the plating.
  4. Shearer inframes, excellent top end pipe. I have a feeling this guy is going to want to much so here are some other options. http://motors.search.ebay.com/search/searc...earch&fgtp=
  5. Here is what mine looked like after I got done chopping.
  6. The guy on ebay that sells the duneables also, he is out of Fl.
  7. Trade you a crank for it.
  8. Tell him you are from the HQ.
  9. Ive paid off 4 bikes now and I havent received a title on any of them, I dont think Arkansas requires title for bikes. Like everyone has stated before check the vin # and have him write a bill of sale.
  10. The lockup is worth it, Like what was stated above you can remove weight to get it setup to where you want. The pandcake bearing is worth putting in no matter what some places sell it for about 30 bucks.
  11. You nee to try asking on Planetsand, there are quite a few asphalt racers there. Not many tha run the 1/4 though.
  12. I have one also...............
  13. Bigboybanshee 350 seems to pull enough gear for the 1/8th but anything past that I would think tq would have an advantage.
  14. There is alot of info on 4mm cubs on Plantetsand.
  15. A small curled pick works well, I forget what they are called though.
  16. The stock airbox is notorious to not sealing properly and letting dirt past the filter, I suggest replacing it with a proflow and K&N I never had any trouble out of mine dusty, muddy or sandy conditons.
  17. If you are broke no it wont be a good buy, you will need to have the cases trenched, buy straight cut gears, lockup and the list goes on. A 4mm cub would be a more cost efficient deal.
  18. More low end power, easier to tune.
  19. I would put a dirtbike motor in it if it were me.
  20. Keep an eye out on ebay for a used one.
  21. I like using that orange citrus stuff.
  22. New banshee and the plastics are already sagging and stress marks, have you rolled the bike? the plastic on my 04 was still holding form fine up until the day I tore it down.
  23. It's not for sale, I was just telling travis that was all that I had.
  24. Just curious, but to me that bike looks a little nice to be trashing to build conversion out of.
  25. When I had my t6's I was running 320 main, middle clip on the needle with a k&n and a pro flow. So IMO I think you are lean.
