gurny
Everything posted by gurny
  1. gurny
    Stock Rear Rims
    I have a set of stock rear rims in good shape. $30 plus shipping. Let me know
  2. Sorry man didn t mean to offend you. Just wanted to make sure. Are you still going to hook me up? Let me know. Thanks
  3. There not bent right? Thanks alot
  4. I did mine with krylon spray paint. It took me forever to tape around the tire but it was worth it. I did 2 coats of primer, 2 coats paint, and 3 coats of clear coat. The paint dosent scratch very easy but it came off a little around the bead from hitting shit. Still looks awsome.
  5. I have one in good shape if that helps, but you probable need both. If you want it or trade one for one let me know.
  6. I need new a new needle for my mikuni carb(stock) . I usually get my jets from magic but they don t have individual needles they want my to buy the kit . I don t need the whole kit. Thanks
  7. gurny
    Rear sand tires
    One of the guys i went to Glamis with has a pair of 8 by 20 sand stars,with 3 hours ride time on them.He wants 100.00 tires only.I live in Yarmouth if your interested.John 329187[/snapback] You live in yarmouth?? Where do you ride around here?? The reason I want the paddles is to ride on nauset beach while there are no cops around. Hope I don t get cought.
  8. Anyone want to sell me just one?? I need an other one so I can use my other rims.
  9. gurny
    Rear sand tires
    I need a set of rear sand tires with rims 4x115. New or used dosen t matter. I don t care what kind of rims there on just some good meat on the tires. Pics would be nice also.
  10. Anybody?
  11. Yeah it will rev good and idle if your firing on one but will not move because of it. This might not even be your problem but it only takes a few minutes to check. Its happened to me before thats why I said it.
  12. I couldn t find any info by searching, so I could get toomey t-4 for a good price now would it be worth it to get rid of my fattys? just want to get some opinions. Thanks
  13. Make sure you are getting spark through the spark plug. If you don t know how to check then, take the spark plug out of the cylinder, plug it into the spark plug cap, then with RUBER handled pliers hold the spark plug cap with the spark plug in it and hold the fireing end against one of your head bolts, and kick your shee over a couple of times.You will be able to see a spark jumping across.That will cancel out the whole spark thing because that will tell you that everything starting at the stator all the way to the cap is good. Let us know how it works out. You might experience a slight shock but nothing that will kill you.
  14. I have a 2000 rear shock on my shee and was wondering if anyone knows if you could rebuild it to make it feel like new again. If so how much and where can I get it or get it done.
  15. 15/41 is the way to go. The gears seem soo much longer in the trails and in a straight away. You will like it.
  16. It might not even be your carb.. When you did the wot was the plug real wet? Might want to check your spark. My shee had almost the same problem I cleaned up the little points on theoutside of the flywheel with a wire brush and made sure my spark plug caps where on tight and that fixed my problem. The reason being is because it didn t have a good contact by the pick up coil and would only fire once every 4 times compared to the other cylinder and it would pop like that because alot of fuel was shot in there and would only fire every couple of times, at high rpms its not as noticeable because its fireing so fast it can kinda keep upwith the extra fuel in the cylinder. Just something else to try. If you have any question just ask
  17. I run amzoil 50:1 and 93 octane @170 psi in each cylinder. Runs great. Your waisting your money. With the money you save you could use it on mods for your shee.
  18. Aprox how much HP does it give you?? For $20 thats cheap where do I send it?? Banshee worx
  19. They are stock painted black and clear coated. They are off an 89, so they are the old style lug patteren and will not fit newer year hubs. Want to get rid of them they just take up space . If you want pics let me know.
  20. I have mikuni carbs. But I will try to call. Thanks chetta
  21. I tried to get them from magic racing but I searched and they only come in kits. Anywhere else I can get them cheap. I also tried my stealership and they don t have them. Thanks, Kevin
  22. Why do you still have the snorkel on???? If you have a air filter and pipes your suposed to take that off let your shee breath alittle better. Try that out if anything drop down to 27.5. Don t forget to check your main jets after removing the snorkel, but you should be ok maybe up a size or two!!!
  23. I put a clear coolant hose on my shee and I can see very small air bobbles in the hose like a foam. Its not getting very hot because its cool to the touch. Is this a problem or not? Shee has run the same.
  24. I bought my clear hose from a fishing supply store. Its a clear braded potable water hose. Works fine gets alittle soft when hot but hasen t melted.
  25. Will stock raptor shocks fit a j-arm frame??
