MIABanshee
Contact Methods
  • AIM
    team305runit
  • ICQ
MIABanshee's Achievements
  1. Yeah I have to check the hose clamps and the water pump cover.... my overflow is relocated to the front.
  2. Hey guys I have some coolant accumulating under the case and dripping when I rev it up.... any ideas on where it could be coming from? Its not too much but enough to notice a little puddle of coolant on the ground. What places should I check for a leak. Thanks
  3. When I hit the powerband or dump the clutch in first gear the chain will make a bad grinding noise with the rear sprocket for a second. I checked to make sure everything was tight... axle nut and chain are both tight. Sprockets and chain are all new.. splines are all tight. I still cant seem to find the problem of why it is griniding .
  4. I need a stock working rear caliper, dont need lines just need a caliper, also pad life doesnt matter.... any one got one? let me know thanks
  5. I was wondering where you can get a rebuild kit for a stock carb.. the float is leaking gas and I need a new valve seat. Where can I find these at? THanks
  6. No im talking about for the cylinder bolts not the head... i know the pattern for the head.
  7. I believe its just criss cross pattern right?
  8. OK guys it turns out it is a leaky base gasket so i tore down the top end put in a new gasket... same problem and its still leaking from the base gasket... could i be doing something wrong? Im torqueing the bolts to 20 pounds is there anything IM missing?
  9. The screw was stripped so bad that I couldnt open it but there I ended up taking out the carb and taking it all apart and cleaning it really well so I'll let you know how it turned out when I start it today.
  10. Carb slide is in the right way.... I'll check the fuel drain screw.
  11. They look awesome... especially if you add the dye. I really havent been able to test out how they work yet because my bike isnt running right yet... but im happy with them so far.
  12. I checked both spark plugs and they both had a good spaark. I heard that if the oil seal is leaking on the fly wheel side that there will be 2 stroke oil aroumd the seal... I check it was dry..... Im really starting to think that its the carb because i Checked the spark plug and it looked almost brand new after idleing it for a little. So i dont even think its getting gas. But I have tried cleaning the carbs out a couple times already. Cleaned out all the jets and sprayed everything with compressed air. Is there anything I could be missing?
  13. this thing idles perfect and revs up awesome in nuetral and starts on first or second kick but right when I put a load on it just wants to die , both cylinders run crappy but the left cylinder barely even runs.
  14. I did do it by taking out the air filter and looking at the slides. They move evenly.
