Bench grinder will work alright. Although, it will be severely uneven, unless you have countless hours on a grinder. :confused: At any rate, you won't be able to do the neutral backcut with none other than a vertical, (or with some managery, a horizontal mill...)mill. This will give you smoother shifting, and less missed shifts, but the neutral backcut is a must if you wish to find neutral with the engine running. :cheers:
I almost forgot, you will need a new clutch cover gasket, and you will have to remove the clutch, which I use an air impact for. Once that is off, you will need a phillips screwdriver, (and sometimes an impact driver) to get the screw out of the shift drum. The Clymer manual shows the star, and the internals. Also, Meat's site, www.TheBansheeZone.com I believe has some pics as well....
290853[/snapback]
Hey man... I've got a star I need modded for a friend... PM me you addy again so I can send it out... I also need your updated email addy for my site (your page)
Thanks dude
290855[/snapback]
If your case gasket is in good shape you can probably re-use it. I have re-used mine a few times now without any issues.
290857[/snapback]
I haven't heard of this back-cut before. Got links? :)
Also, is this better than this gizmo I've heard good things about? http://www.shiftpro.com/shift-pro_new_001.htm
I have an '00 shee, and it's next to impossibe to get into neutral with the engine running. Before that, I had a '96 shee and after 6 years with it, neutral was never as hard to find as it is on this '00.
TIA,
_dennis
TIA,
_dennis
291009[/snapback]
Here is my Shift star thats back cut
well i did the mod. today with a dremmel tool and a bench grinder looks like it came out really good. however when i pulled my clutch off i notced that the clutch housing has a little play like the ribbits are worn or something i can grab the gear and turn the housing about a 1/4 of an inch each way.is this normal?
Can you buy an aftermarket shift star for the Banshee? My '00 is a pain in the ass to shift into neutral and it misses sometimes.
TIA,
_dennis
291009[/snapback]
The neutral mod works very well, before I did it to mine it was very difficult to get in neutral with it running, now it's a breeze.
Here's a link to a pic of mine for comparison, I don't do these anymore.
Shift star with backcut neutral
291364[/snapback]
Cascade-Innovations.com / Cascade in Oregon had/has them for $30....
