All Activity
- Yesterday
Thanks for the response and I laughed really hard at “it’s a banshee not a jet-ski” Lol. I swear I have said that before. The trails i ride on are the kind you either need a side by side, a dirtbike, or a 4x4 yes. Today I am gonna put the 25 pilots back in and see what happens because I’ve never tried them with the lid on. I am also looking to upgrade to a proflow filter but not k&n
Back in February of this year I purchased my 05 Banshee. It’s basically stock other than the Toomey T5’s, Toomey perfect jet kit and a Pro Design pro flow filter kit with the K&N filter and Outerwear that was installed by the previous owner. My elevation here is roughly 800 ft above sea level and my outside temperature varies from 50 degrees and can go up to 90 degrees depending on the time of year. I also heard that humidity can play an huge role and can affect the jetting as well. I have stock carbs with the TORS deleted by the previous owner. I was given the extra 270 & 290 main jets if I needed them for later down the road. So right now I have 280 main jets with stock pilots, clip is on the 4th groove on the Toomey needle and my air screw is at 1.5 turns out. I also use 95 octane ethanol free gas with a 32:1 mixture. I ride in a mix of terrain that is dusty, a little bit of mud and a couple of shallow water crossings which are anywhere from about 6”- 18” inches deep depending on the rain fall in the area. I avoid really deep water( it’s a Banshee not a Jet Ski ) and I don’t fly through the water crossings either because I don’t run a lid on my air box, but I do use a Outerwear that is dust proof and water repellent on my K&N filter and I don’t have any problems with the filter setup, but before I do anything I check the filter & Outerwear to make sure that everything is clean, tight and in working condition before I do any kind of riding. From what I read on here in some of the really old posts that they are saying that the stock air filter setup is completely garbage and that it should be the first modification that should be done when buying a new Banshee. How muddy are the trails that you ride on ? Are they the type of trails that you need a 4x4 quad to ride on ?
- Last week
Can I put Yfz 450 front calipers on a j arm banshee?
Best brand of nerf bars to buy?
locogato11283 replied to HeavyHauler's topic in Banshee Repairs and Mods
I always had AC Pro Pegs.. I don't think they make them anymore. These looks pretty nice.. https://www.ebay.com/itm/164391962291?fits=Make%3AYamaha&itmmeta=01HXQ0H6FAPF8VR39QNAK9JKBT&hash=item26468646b3:g:pmsAAOSwsB9WDB~S&itmprp=enc%3AAQAJAAAA8B%2BiDDe343roRuo7GWwpTsNUTgaYFf4MxezyG%2Bw6S2xGe8X5F8mW6jkVWCLkXq0hPDDVD2uXOa5W7r%2FLTVHkcwqq9Fuv2Kv%2FojzkBkx1trd8bfz49b4KpAEwq44WNhAB%2BU5drEQmAw9HmUoseZNPmtVUv85Yb06mWYPlDgOObd2JlTweM3fGco4TUKYNPPoHQ8rpr%2B1qoPs2YMfFpsS5pGJDTC%2F65RbR8iokP2vqZZtM%2FQqNqmV8axe07mNzEpBTkX0%2B2Qp%2Fmz6S1OMGimedvTIyfgkkmJUvX%2Bq6Zii1oMuaQgMmlX3pGUEs3OtpUsmZ9A%3D%3D|tkp%3ABk9SR97nxODtYw -
Noonie joined the community
No Problem my issues with Alba etc are just built to a lower standard Like look behind their heelguard the main pipes bend ends in the middle of nowhere doesn't end nice and clean on the subframe tab to add a little of reinforcement. Same with no Tube under the expansion chambers to join the two front sections of the bars together. You are adding a lot more pressure on the footpeg mounts of the frame. XFR doesn't have this issue because they spent a little more designing the bars to work with the mounting points of the frame but your heel guards are now closer on the XFR's to the kick starter and you will need to change your style of kicking to just using your heel especially if you are wearing boots or you wont be able to kick it over. If you want no issues, the best fitment out of the box and most durable bars for the banshee there isn't really a better option than the 43's.
1989 Banshee J-arm front brake calipers
hoppedupandcutdown replied to bigred250's topic in Banshee Repairs and Mods
The extended ears for the caliper mount on the spindle and the lack of countersink on the hub for the rotor bolts tells me you for sure have the early stuff. -
Never had the lid on with 30’s. And I ride some dusty/muddy trails. I tried running without the lid but my air filter was covered in dust after 1 ride so I wanna keep that to a minimum
MrNeves7 joined the community
Hi i need some advice, I took off my exhaust to polish them and decided to have a look at the pistons and noticed that on the one piston. Do you guys have any advice if it’s safe or not or is it time to replace them. I feel very skeptical about it but I’m not a mechanic. IMG_3844.mov
When you had the 30 pilots in did you ever try it with the air box lid on ? What type of riding conditions are you riding in that requires the air box lid ?
JerzOutlaw350 started following 1989 Banshee J-arm front brake calipers
JerzOutlaw350 replied to bigred250's topic in Banshee Repairs and Mods
The picture of the J-arm spindle / knuckle that you posted “ IS “ for the model year 87-89 which requires part # 1UY-23501-01-00 Left Side & 1UY-23502-01-00 Right Side. Then for the A-arm spindle / knuckle for the model year 90-06 which requires part # 3GD-23501-10-00 Left Side & 3GD-23502-10-00 Right Side. Here is a picture of what the spindle / knuckle looks like for the 90-06 Banshee. The picture that I posted is from a 1997 Banshee that Im currently working on for a friend. If you look the picture that you posted and compare it to the picture that I posted you can definitely see the difference between the spindles. I also circled the caliper bracket bolts in my picture to show how the spacing is different from the 87-89 Banshee in your photo and the 90-06 Banshee that is in the photo that I posted. Sent from my iPhone using Tapatalk -
I have 2003 Triple Ported Athena Cylinders, Stock bore, Stock Head no domes, Ethanol free Gas 32:1, Full Toomey 5’s, Stock Carbs with Toomey Needles, stock intake, stock reeds. Stock airfilter and airbox. I want to use the lid but NO snorkel. I do NOT want to drill holes in my airbox. My elevation is 1000ft and temp is 70+ degrees on average lately. Right now I’m running 270 Main, 27.5 pilot 1.5 turns out, 4th clip on Toomey Needle(6 slots). When I ride it now it feels like it stops pulling towards the top end almost like a flat spot 3/4 to WO throttle. When I had 30 pilots in here with no airbox lid this thing would wheelie in every gear but where I ride I need an airbox lid. What do you guys think on my jetting?
DonJuan joined the community
bigred250 replied to bigred250's topic in Banshee Repairs and Mods
Can anyone verify if I have the 87-89 spindles? I would hate to buy the 87-89 brake calipers just to find out later that the spindle has been changed to the 90-06 style. -
375hp banshees started following 1989 Banshee J-arm front brake calipers
375hp banshees replied to bigred250's topic in Banshee Repairs and Mods
Im just here to say hi to jerrod. Just to find out its only 250 ...not bigred350X I think 89 stuff was only the same a few years tho &OG's right ...wc or redo are good choices -
HeavyHauler replied to HeavyHauler's topic in Banshee Repairs and Mods
@Fearnot Thank you for the info about the Factory 43 nerf bars. I’ll have to look into them. I haven’t bought anything yet. -
Check with either one of them. They may have what you are looking for. https://westcoastatvparts.com/ https://redo-parts.com/ -
I bought an 89 J-arm Banshee and it is missing the entire front brake system. Will the A-arm 91-06 Brake calipers work? Picture of hub and spindle below. Thanks https://ibb.co/93d89G4
bigred250 joined the community
Factory 43 and nothing really comes close besides older AC Racing units. If you are looking for the best no budget the 43's and thats coming from someone with XFR's
I've been interested in gambling in Canada for a long time because thanks to online casinos, I often win real money just by playing games. If you are a beginner and don't know where to play, then pay attention to All Slots Casino site has a detailed review where you can learn about its benefits. You can read information about bonuses, the selection of slot machines, and you will also learn how to quickly register and create your own account. This online casino accepts players from Canada, and you are sure to get your nice welcome bonus.
AnnaVello joined the community
C C I bet
Juega Bet es una plataforma de apuestas en línea que ofrece una amplia variedad de opciones para los aficionados al deporte y los juegos de casino.
adam21 joined the community
Sorry you couldn't be small spoon with Skeeter.
ahah,so many students lol
thomasxzcx joined the community
Dimbulb changed their profile photo
Dimbulb joined the community
Most active thread on the website!
Well, that event was as lame as we all predicted!
