All Activity
- Past hour
[emoji106] Sent from my iPhone using Tapatalk
Your building another banshee? Sent from my iPhone using Tapatalk
- Yesterday
No. Leave it alone.
Well?
There's a guy on FB named Ben Martins that rebuilds these.
Likely a Vito's style set.
Still alive?
Still running Snipers on my 421 Serval.
Green has never shown his face at LOTO even though he's supposed to be moving there.
Wonder if he ever bought anything.
Fucking WCJ.. Haha. Dude got so embarrassed about now showing up the the BansheeHQ ride that year he bounced.
Hey What’s Up HQ’ers! I have a returning customer with a 98’ Banshee with a completely stock engine that I have worked on in the past. He brought it to me yesterday saying it has a problem with extreme loss of power and shuts off after about an hour of riding. He said if he lets it sit and cool down for about 25 to 30 minutes then restarts it to ride it again the problem comes back about the same time frame. So this is where I come in. I looked it over and I took it for a test ride. It did it to me just ripping it up and down my stone driveway. In no way it’s overheating. I removed the keihin carbs and checked them over and they were clean of any signs of contamination. He runs VP C9 for fuel and Klotz Super Techniplate at 32:1. I checked the reed and they were good. I switched all the electrical components from a known good running Banshee and nothing changed. The clutch is working properly. The front and rear brakes are working properly nothing hanging up. I did a compression test both cold and at operating temperature. Cylinders at cold was 110 and cylinders at operating temp was 115. Did a leak down test and it sat at 6 psi over night with no pressure loss. No engine noises present. The Banshee runs and rides normally. Now this morning I brought it out and started it up and let it warm up for about 4-5 minutes. Took it out for a rip nearby my house and I got it nice and hot the it did it. Now I noticed with the engine hot it feels like it’s got a ton of compression. So I got it restarted and limped it back to my house and it still feels like it has a ton of compression. I removed the spark plugs and nothing changed. So I drained all the coolant out of the system and removed the cylinder head and cylinders. Pistons and cylinder bores seems to be okay with just a slight sign of normal wear. Probably could just get away with new wrist pin bearings and rings on the pistons if needed. But that plan got blown out the window. When I went to check the crank. That’s where I found the problem. The lower rod bearings feel really crunchy with a small amount of side to side play with more being on the right side. Then when spinning the crank it self the main bearings also have a small amount of crunchy feeling and a small amount drag. I think he was lucky to catch this before it turned into something very catastrophic. So I’m going to be giving him an update on my findings today to find out what direction he wants to do moving forward with rebuilding it. I’ll be back with an updated soon. Thanks
- Last week
[emoji897] [emoji897] [emoji897] Sent from my iPhone using Tapatalk
Crank is done! $$$$ 2BKING 🤑
- Earlier
locogato11283 started following 2026 BansheeHQ Spring Ride
locogato11283 replied to locogato11283's topic in Riding and Events Forum
Yes. -
Did this happen?
We did get the cylinders in Mar., but nothing can be done until we get the rods changed out on the crank. We took the crank to Crank Works for rebuild & rod length change in May. We'll see how long it takes. When we get the crank back, we can start on the porting & mock-up. Then have domes cut & get cylinders out for plating. It would be nice to have this all done before the end of Sept. but that's wishful thinking! 2BKING 👽
La sección de curling en vivo de https://jugabet.cl/curling/live/1 permite seguir partidos con actualizaciones en tiempo real, resultados y detalles de cada ronda. Los aficionados pueden observar el desarrollo estratégico de cada encuentro y mantenerse informados durante toda la competición. La plataforma es sencilla de usar, funciona bien en móvil y ordenador, y ofrece una forma práctica de seguir este deporte con precisión y detalle.
For sale is my 2001 Banshee that I’ve owned since new. Lightly ridden off and on for about 10 years — low estimated total chassis hours. Always well maintained. Key Build Specs: Patriot Racing 75HP dune port by Dan Bottom end balanced by Dan at Patriot in 2002 Top end freshly machined by Lake's Motorsports with .020 over 64.5mm Wiseco forged pistons – Maybe ridden 10 hours since then Coolhead with NOS/Pro Design-style domes Dyna FS programmable CDI Toomey T5 pipes, recently repacked silencers. 28mm Keihin PWK carbs with plenty of jets. Well tuned for here. Magura hydraulic clutch Lock-up clutch with adjustable arms Brembo front brake Full long travel suspension: Long Travel A-arms, DuraBlue +6" rear axle, Elka Stage 5 front & rear shocks (full compression & rebound adjustable), Elka System 5 steering damper Extended steering stem with damped bars. New tires: Front 23x7-10, Rear 22x12-9 SunF aggressive tires with DWT rim covers DG race pegs & nerf bars, DG six-pack rear rack, DG front bumper New 5.1 gallon plastic tank Floated stator, Trail Tech regulator/rectifier, bright LED lighting Billet clutch cover + billet stator cover Extras Included: Full spare sand tire/wheel set: Kenda Dominator 22x11-10 rears + ITP Sand Star 22x8-10 fronts on Douglas wheels (excellent condition) Complete Nitrogen cylinder + regulator + stainless steel hose for charging the Elkas. Original blue plastics with wear and sticker (solid and straight, easy to refresh). Everything else on the bike is sorted and performance-focused. This is a complete, turn-key 70HP dune rocket that runs well. Strong first-crank starts, crisp power delivery, and planted handling in the sand. Located in Las Cruces, NM. Local pickup preferred with cash/test ride. Serious out-of-state buyers welcome with deposit and video verification. Shipping available at buyer’s cost. Asking $13,500 OBO Serious inquiries only. Feel free to message with any questions. Coldstart from two different angles.
