So ive been jetting my shee for the past couple of weeks. So i finally got it about right and it had a high RPM miss so i replaced the spark plug caps. Fixed that problem and she ran great for about 30 minutes. Then she dropped the right cylinder. its hard to start after she has been sitting for a little while. once started she will fire on the right side but if i put her in gear and try to go she loses all power and dies. What could it be Stator? Reeds?
so you replaced the plug caps, but not the whole coil? sounds like your coil could be bad.
what does your spark look like? weak spark? good spark?
Yeah I replaced just the caps. I had the coil tested at the dealership about a month ago. probaly take it back and let them test it again. sparks looks Decent
have you checked the two tabs your coil bolts to? those tabs have to be bare metal.. thats how the coil is grounded. i bet yours are rusted...
I sanded the tabs on the coil down and the tabs on the frame to bare metal. Still having the same issues. Anything else?
