What jets are you using? Fill out this form...
1) What type of aftermarket exhaust do you have? (Paul Turner Mids with fatboy 2 silencers)
2) What type of airfilter do you have? K&N
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all (Stock airbox with proflow adaptor and K&N powerlid)
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) (600-800 ft. above)
5) What size pilot jets are you using? (27.5)
6) What size main jets are you using? (300)
7) What temperature is your Banshee jetted for? (60-90 degress F)
8) Do you have a port job? (stock port)
9) What kind of carbs? (stock TORS removed)
10) What size carbs? (stock TORS removed)
Needle clip 2nd postion from top due to VF2 reeds
1) What type of aftermarket exhaust do you have? stock
2) What type of airfilter do you have? Pro Flo
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all ... YES
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 4200ft and 8200ft
5) What size pilot jets are you using? idk i guess stock.. the guys i bought it from ran it at red sands new mexico and mentioned that he put new jetts and they we 38 s
6) What size main jets are you using? 38
7) What temperature is your Banshee jetted for? 90s
8) Do you have a port job? no
9) What kind of carbs? stock
10) What size carbs? stock
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? FMF Fattys
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all STOCK air box no lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1500 ft.
5) What size pilot jets are you using? 27.5
6) What size main jets are you using? 290
7) What temperature is your Banshee jetted for? 60-90 degress F
8) Do you have a port job? stock port
9) What kind of carbs? stock TORS removed
10) What size carbs? stock TORS removed
Also run VF2, +4 timing, and needle is in the middle position.
1) What type of aftermarket exhaust do you have? CPI inframe
2) What type of airfilter do you have? pod K&N
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 4500'
5) What size pilot jets are you using? ??
6) What size main jets are you using? 380
7) What temperature is your Banshee jetted for? 70
8) Do you have a port job? 196 Exhaust and 130 transfer
9) What kind of carbs? Mikuni
10) What size carbs? 30mm
Edited by sahara
1) What type of aftermarket exhaust do you have?T5
2) What type of airfilter do you have?K&N pods
3) d) no airbox at all
4) What is your elevation? Sea Level
5) What size pilot jets are you using?27.5
6) What size main jets are you using?340
7) What temperature is your Banshee jetted for?80ish
8) Do you have a port job?MX?
9) What kind of carbs?Stock
10) What size carbs?Bored to 28mm
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? Toomey T-5
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No Airbox
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2750 Feet
6) What size main jets are you using? 155
7) What temperature is your Banshee jetted for? 20c/65f
8) Do you have a port job? NO
9) What kind of carbs? Kehinen
10) What size carbs? 35mm
Please copy and paste this along with your answers in your reply, thanks.
1) What type of aftermarket exhaust do you have? toomey t6
2) What type of airfilter do you have? stock filter
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all modified airbox
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 3000 ish
6) What size main jets are you using? 280
7) What temperature is your Banshee jetted for? mild
9) What kind of carbs? mikuni
10) What size carbs? 26
Thanks!
Thanks!
dude, you stole my name..
that is my username on my chainsaw forum..
ive also seen a banshee67 on raptorforum in the past
i better change mine before i get tied in with the likes of you guys
1) What type of aftermarket exhaust do you have? procircuit w/ 304 silencers
2) What type of airfilter do you have? k&n pods
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all: d
4) What is your elevation? 600-800
5) What size pilot jets are you using? 48
6) What size main jets are you using? 152
7) What temperature is your Banshee jetted for? 80's or so
8) Do you have a port job? yes, clean up port
9) What kind of carbs? keihin pwk
10) What size carbs? 28
-also i'm 1 turn out on air screw and running w/ +4 timing
  • Like 1
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? fatty pc2
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? A
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1460
5) What size pilot jets are you using? 27.5 1.5 turns out
6) What size main jets are you using? 260
7) What temperature is your Banshee jetted for? 15C
10) What size carbs? 26mm
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? DMC 916
2) What type of airfilter do you have? Pro design foam filter
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. Stock/ power core lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 0 - 316 metres
5) What size pilot jets are you using? 42
7) What temperature is your Banshee jetted for? 25 c
9) What kind of carbs? PWK
  • 3 weeks later...
1) What type of aftermarket exhaust do you have? Pro Circuit Platinums
2) What type of airfilter do you have? K&N Stock rplacement
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all.
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 900ft
6) What size main jets are you using? 280 summer/300 winter; Needle clip on pos. 4 (1 richer than Center)
7) What temperature is your Banshee jetted for? 60 - 100 summer/30 - 60 winter
8) Do you have a port job? Yes, don't know any details
9) What kind of carbs? Stock Mikuni VM26SS
1) What type of aftermarket exhaust do you have? T5
2) What type of airfilter do you have? UNI w/ ProFlow
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? B
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2700
5) What size pilot jets are you using? Stock
7) What temperature is your Banshee jetted for? 75-95
8) Do you have a port job? No
10) What size carbs? Stock
11) 50:1 Premix
Thanks!
1) What type of aftermarket exhaust do you have? T5s
B
600-700
5) What size pilot jets are you using?stock
6) What size main jets are you using? 270
7) What temperature is your Banshee jetted for? 70-90
9) What kind of carbs?stock
10) What size carbs?stock
  • 4 weeks later...
1) What type of aftermarket exhaust do you have? fmf gold
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all vented...
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 920ft
7) What temperature is your Banshee jetted for? 50-80
