rockenshee
Everything posted by rockenshee
got some skate trak edge tires will test them out in 5 days time thanks for the info
removing the tors makes it a lot easyer to sync you carbs and tune it
because il like some sand tyres put dont whant to spend a lot of money smart ass
il stick to my razrs in the dunes its to much money to get sand tires for only 3 rides a year in the dunes
worked out it was the throttle cable so i removed the tors then instaled a tors elim kit and ear screws ges what both carbs are in sync at idle and 1\4 throttle thanks for the info all of u
the black box is it the one next to the coil?
drill the holes out to 10mm then turn the timing plate to the right then tighten the bolts put some lock tight on the threats
they are both on and in good condition
06 model tors on cable 4 years old did work on carby last break tuned carby after i instaled pipes k&n filter in box and pro series reeds +4 timing did the reeds and +4 2 months ago and the rest of the mods 3 weeks ago after tuning for my mods i synced the carbs by eye slides lifted at the same time when i was tuning picked up that it was smoking more out of the left pipe bike ran as normal this week got the sync tool removed the air box and boots placed tool on back of left carby reading is higher than right carby left was 5 right was 3 that is when the slides go up at the same time work i did to the cabys is changed mains to 260 pilot to 27.5 air screw 1.5 turns out needle clip to 2nd from the top can the cable move out of the track in the tors or can the pilot be blocked alittle when i sync the carbs with the tool smokes same on both pipes put slides dont lift up even
tusk hd
fmf pc2 +4 timing pro serie seeds k&n filter no snorkel
Is it possible to put a winch on a Banshee?
rockenshee replied to ninjamaster's topic in Banshee Repairs and Mods
if u need a winch u are not riding hard at all -
some help pls want to ride tomorow
adjusted both carbs the same at 1/4 throttle then let it idle right carb was out ? when i open the throttle a bit and hold the sync tool on the carb the vacuim gose up a lot faster on the left carb then the right one
when i sync at idel both readings are the same 2.5 on the sync tool its a vacium gauge but when i open the thotle a bit the left carb reads 6 and the right carb reads 3 do i have a air leak after my carbs or is it something els? help
milling .020" what hp increase will it ad running premium unleaded
only ride in the dunes 3 times a year what do you recomend
x2 real good pipe cant the front wheels down go +4 timing , reeds , k&n filter jet it right it keeps me happy
Thumb for me you turn the handelbars to mutch on the quad
is my jetting about right need input
rockenshee replied to rockenshee's topic in Jetting & Exhaust Forum
it was running a bit rich before going up on the pilot when i started jetting my bike i started with the mains first got it nerly spot on litle rich maby one to big on the main then i played with the pilot to get 1/8 throttle spot on whent to 27.5 pilot and moved the needle clip up one its may be back to front put it sounds i did it right in the end -
1) What type of aftermarket exhaust do you have? fatty pc2 2) What type of airfilter do you have? k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? A 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1460 5) What size pilot jets are you using? 27.5 1.5 turns out 6) What size main jets are you using? 260 7) What temperature is your Banshee jetted for? 15C 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? 26mm 11) +4 timing 12) pro series reeds 13) needel 2nd from top i started with 290 mains and worked my way down to 260 mains this is my first time jetting my bike i whent frome 25 pilots to 27.5 pilots looked to me that going up one pilot ment that in going this i had to go down 2 main jet sizes is this tru did plug chop on 260 mians and looked spot on to me 260 did i do my jetting right? just whant to be spot on
What jets are you using? Fill out this form...
rockenshee replied to vortechblown306's topic in Jetting & Exhaust Forum
1) What type of aftermarket exhaust do you have? fatty pc2 2) What type of airfilter do you have? k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? A 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1460 5) What size pilot jets are you using? 27.5 1.5 turns out 6) What size main jets are you using? 260 7) What temperature is your Banshee jetted for? 15C 8) Do you have a port job? no 9) What kind of carbs? stock 10) What size carbs? 26mm -
i mix 40:1 2R yamalube in 98 oct how long is it good for ones its mixed ?
