ritchieb
Everything posted by ritchieb
  1. Phil has great communication and made the effort to ship to Australia, which I appreciate. Thanks again, Ritchie
  2. Great seller with excellent comunication, which makes it easy to do business with. Shipped quickly too!!!!
  3. Joe is a great seller & his communication skill left no doubts about the item or shipping to Australia. Radiator was packaged well, with both bubble wrap and paper. Wouldn't hesitate in buying from Joe again!
  4. PM me on how much do you want for the air box & snorkle + shipping to Australia? Thanks
  5. ??????? The left side must have air trapped. Once you have a little presure, with the brake lever pulled in & you open the bleed screw on the left caliper does brake fluid came out? Make sure the bleed screw is not blocked. Or pop the piston inspect and clean.You say you just purchased it, what was the brake fluid like, contaminated?
  6. Thats right, just where the seal contacts the crank.Just so there not dry. For intallation & initial start up.
  7. Love the seat, love the look, everything just has that flow to it. hay it's friday after some well earned beers. CHEERS !!!
  8. It's an easy job to replace the kick starter axle. Just need to tip the bike on the PTO side ( sprocket side) and remove clutch cover, (so you don't have to drain the oil) to get to the clutch assembly. But if you buy it you would want to change the oil. If you don't have a manual you should get one, there handy. Cheap to fix too.
  9. Hi, with your package, cylinders, crank & head, what carbs (sizing) & pipes would give the best dune - trail proformance( power) 98 RON fuel. Thanks
  10. Tony stands by what he sells. Prices & shipping were great. Offered to pay return shipping if part wasn't as described. Now thats backing up what you sell! Im from Australia, and you have to trust the seller, there was no problem with Tony. Add to this his great communiction skills which made the transaction go smoothly. Thankyou!
  11. I'll take it, dependig if you will ship to Australia & shipping cost.
  12. I work too much. Family time yes, banshee time NO !
  13. x2 Good quick reference guide.
  14. 1st time dealing with NYUK. He is true to his word.No fuss no drama, the way it should be. Being an international buyer you have to be carefull for dudes that just want to make a quick buck out of you for bodgie parts.Not the case here, I would highly recommend. Thanks John
  15. Thats right, inline with the piston pin (90 degrees to exhaust)If no contact is made with one strand, double it up by twisting two strands together. Cheers
  16. I've been chasing those cases for days now, you gave me a price shipped, been PMing for days.....???? No reply
  17. Post or email some pics please on cases at [email protected] Thanks
  18. First time dealing with,Great seller, iterm as described & quick with the PM's Thanks again
  19. Thanks for the quick reply.
  20. Hi, does anyone know the dimension of a stock barrel from deck to base? Thanks
  21. Hi, do you still have the cases? Do you do international shipping? If so how much to ship to Melbourne Australia? Thanks
  22. Hi,do you still have the internal bits & pieces? I'm interested.
