Joe is a great seller & his communication skill left no doubts about the item or shipping to Australia. Radiator was packaged well, with both bubble wrap and paper. Wouldn't hesitate in buying from Joe again!
??????? The left side must have air trapped. Once you have a little presure, with the brake lever pulled in & you open the bleed screw on the left caliper does brake fluid came out? Make sure the bleed screw is not blocked. Or pop the piston inspect and clean.You say you just purchased it, what was the brake fluid like, contaminated?
It's an easy job to replace the kick starter axle. Just need to tip the bike on the PTO side ( sprocket side) and remove clutch cover, (so you don't have to drain the oil) to get to the clutch assembly. But if you buy it you would want to change the oil. If you don't have a manual you should get one, there handy. Cheap to fix too.
Tony stands by what he sells. Prices & shipping were great. Offered to pay return shipping if part wasn't as described. Now thats backing up what you sell! Im from Australia, and you have to trust the seller, there was no problem with Tony. Add to this his great communiction skills which made the transaction go smoothly. Thankyou!
I am fine ,not fishing now need some vacation time i herd there is to many fish . alaska the ocean of the 100 lb cod .it is hard to get the monsters.talk to you later richie .
