Lean=too small of main jets, needle too low, too small pilot/not enough fuel per intake air charge=burn down
Rich=too large of main jets, needle too high, too large pilot/too much fuel per intake air charge=poor performance, fouled plugs, hard starting
Stoich=perfect jetting/optimal fuel-air charge=optimal performace, easy starting, long engine/plug life
I knew this stuff but it's always nice to hear it another way. Maybe a little catchy and easier to remember. :thumbsup: :thumbsup: Nice job. The only stupid question is the one you don't ask.
ive seen this shit happen before so be careful
rich=not so mutch power and uses more fuel
lean=more power,use less fuel, and if not corrected will land you a fucked up engine.
i know from experience dude,,not me but a guy i know,,no no but you could imagine what itd be like!!! :biggrin:
lean sounds like it's running inside a tunnel....popping and gurgling.... idling real high then cutting out...@ WOT cuts in and out or doesn't run at all
rich sounds dirty and makes lots of smoke... low idle or no idle...@ WOT it just dogs.
.02
You can run rich all day long and only have to worry about plugs. You can only run lean a little while and swap out the motor.
Rich the engine will bog some but will run. Lean the engine will surge and finally die.
