i actually run cool head pro design with 16cc dome on one of my motor, but i build a new motor and i need to run with 15cc dome. Buy new head and new dome, or oringed stock head and milled the head. If i mill the head, how many 0,90 or more? to have the same compression of the 15cc. What is the cost difference, the cooling difference...
thank you
banshee qc
Milling the stock head isnt exactly how you wanna go about it. It needs to be re-chambered properly by someone who knows what they're doing. You must be at high elevation to need 15cc chambers.
wow.. people thought i was crazy because i wanted to run some 17's (which ar for sale ).....
im goin to be runnin a k&t head on my bike...
what elevation are u riding and what kind of motor and riding do u do ??
It's a banshee stock stroke drag motor, drag ported stock jug, i don't know the actual elevation, but with my 16cc, i'm at 190psi both cylinder. I run with alky and with race gas or av gas.
Dang you should figure out the elevation, might be time for a rebuild if you need 16cc domes to get that kinda compression. The porting can sometimes effect it but that's alot lol
you might want to ask around but i don't believe you can get 16cc out of a stock head.so go with the aftermarket domes for a cool or noss head
you are sure, i thinK 190 IT'S GOOD, i actually have new piston and ring, my cylinder are heavy ported,
What compression you run on your drag shee?
