Hey I just pulled my cylinders to send to Kevin at Herr juggs racing..Dune/Hillshoot port...I burned a hole in one of my pistons and when I pulled the cylinder there was a little bit of metal particles around where the cylinder slid in..It doesnt look like any got down in my crank but is there any right way to get all the paticles out or just carefully wipre them out?
clean up as much as you can use one of those magnitized antennas then drain your oil and see how much is in there. Youll get the idea weather it needs pulled apart ot not is how I would do it.
to be on the safe side i would just split the cases and make sure everything is out of there.draining the oil won't do anything being there is no oil to drain in the crank case.its all in the tranny
