dragbanshee Posted June 19, 2008 Report Posted June 19, 2008 Need some pics of your wheelie bars on or off the bike or descriptions of how their mounted. I want to fabricate or buy one, Im just not sure how it would mount down low, Id really appreciate some pics or info. Thanks guys! Quote
dragbanshee Posted June 20, 2008 Author Report Posted June 20, 2008 who does sell wheelie bars ? Heard of an outfit called 3Gs or something like that. Quote
shanYE west Posted June 20, 2008 Report Posted June 20, 2008 who does sell wheelie bars ? Tyson racing sells them.. Probably just about any frame builder would sell them. Quote
mia-shee Posted June 20, 2008 Report Posted June 20, 2008 Need some pics of your wheelie bars on or off the bike or descriptions of how their mounted. I want to fabricate or buy one, Im just not sure how it would mount down low, Id really appreciate some pics or info. Thanks guys! Here's a pic of my wheelie bar. I hope it helps. wheelie bar Quote
mia-shee Posted June 20, 2008 Report Posted June 20, 2008 Here's a pic of my wheelie bar. I hope it helps. wheelie bar Here's another pic. I can give you more detailed pics when i get off of work.wheelie bar 2 Quote
yfzdunejumper Posted June 20, 2008 Report Posted June 20, 2008 A good way to make one IMO is attach it to the two pinch bolts on your swinger (that hold your carrier) and to a rear strut. If you buy one you might also call gt performance 816-450-8580. Quote
dragbanshee Posted June 21, 2008 Author Report Posted June 21, 2008 Here's another pic. I can give you more detailed pics when i get off of work.wheelie bar 2 How is the top link attached, maybe a lowering block? I thought about the pinch bolts but I wasn't sure there was clearance between the sprocket bolts and the thickness of the attached bar bracket. Also wondering how strong it is with the three mounting points so close together, it looks good I just want to know how strong it is. thanks! Quote
mia-shee Posted June 24, 2008 Report Posted June 24, 2008 How is the top link attached, maybe a lowering block? I thought about the pinch bolts but I wasn't sure there was clearance between the sprocket bolts and the thickness of the attached bar bracket. Also wondering how strong it is with the three mounting points so close together, it looks good I just want to know how strong it is. thanks! It's has worked very good for me. But all i have is a stock stroke drag ported motor. here are a few pics so you can see how it mounts. pic 1 pic 2 pic 3 Quote
00tbanshee Posted June 27, 2008 Report Posted June 27, 2008 if you are running a solid strut on the back you can mount it like the pictures i sent you.if you want to run a shock you will have to make a bracket on the swingarm for the top bar to mount to Quote
dragbanshee Posted June 28, 2008 Author Report Posted June 28, 2008 Thanks for the info and pics everybody, and that was a good idea on the top bracket mia-shee. From the 1st pics I thought you may of attached it to the lowering block. Quote
