Need some pics of your wheelie bars on or off the bike or descriptions of how their mounted. I want to fabricate or buy one, Im just not sure how it would mount down low, Id really appreciate some pics or info. Thanks guys!
Here's a pic of my wheelie bar. I hope it helps.
wheelie bar
Here's another pic. I can give you more detailed pics when i get off of work.wheelie bar 2
How is the top link attached, maybe a lowering block? I thought about the pinch bolts but I wasn't sure there was clearance between the sprocket bolts and the thickness of the attached bar bracket. Also wondering how strong it is with the three mounting points so close together, it looks good I just want to know how strong it is. thanks!
It's has worked very good for me. But all i have is a stock stroke drag ported motor.
here are a few pics so you can see how it mounts.
pic 1
pic 2
pic 3
if you are running a solid strut on the back you can mount it like the pictures i sent you.if you want to run a shock you will have to make a bracket on the swingarm for the top bar to mount to
Thanks for the info and pics everybody, and that was a good idea on the top bracket mia-shee. From the 1st pics I thought you may of attached it to the lowering block.
