:mellow: Need help transmission makes noise in 2nd gear it sounds like the chain is skipping but not the. Had the motor apart the trans looked good 1 shift fork was grooved on the 2nd gear side and was replasted. Put it back together and has the same problem
NEED HELP
Does the trans make noise in any other gears? Also does the bike feel like it does`t wont to move in secont gear? if the chain is slipping it would do it in more then one gear. when you had the trans apart did you check the main shaft splines?
:mellow: It only makes the noise in 2nd gear. I checked the chain slide and rollers there all good.
As for the trans gear shaft splines they felt good and the clutch was good. It doesn't have the lower motor mount bars but if you think it would help i can get some. Any more help would be great
mine is doing this too, only in second it seems. worn engine mounts will do it? that would be better than the tranny being bad i guess. my sprockets are good and i tightened up the chain to the point of being too tight and it still did it.
It isn't the shift forks..it would pop out of gear, or not go into a specific gear if they were bent. I'm not familiar with this problem.
  • 2 years later...
Sorry for the old bump, but i have the same issue. At full power in second only it feels like it jumps out of gear and right back.
Any other ideas on what this could be? My chain and mounts lok fine
