I got a Direct Drive lockup cover ring. This is just the billit ring that bolts to the cover. It has a clear lexan that would work but probably should be replaced. It is the 6 bolt designe. 6 bolts that hold it to the cover, and 6 bolts hold the lexan to the ring.
50 bucks shipped.
josh
Here are some pics. Like I said you the lexan would work but should be reaplaced. There are a few cracks around the bolt holes. The cracks start at the bot hole and goes out to the edge, not inward to cause a leak so it would work. I tried to get a pic (last Pic)
