longmont Posted June 3, 2008 Report Posted June 3, 2008 just rebuilt the top end now it's running ruff. When i try to take off in first gear at low rpms it dies.If I rap her out and take off it runs fine.So there is no low range just all or nothing. Could it need to be re jetted or carbs ajusted. I havent had the shee long and it has some aftermarket carbs.I dont no what size. What jet should I run at mile high altitude? also I just put new reeds in Thans hope you can help. Quote
notatallhappy Posted June 3, 2008 Report Posted June 3, 2008 check and make sure your carb slides are in correct cut away should be towards the rear Quote
longmont Posted June 4, 2008 Author Report Posted June 4, 2008 check and make sure your carb slides are in correct cut away should be towards the rear thanks I'll check it out Quote
