longmont
About longmont
  • Birthday 03/13/1981
    colorado
  • Interests
    sand,dirt, rocks,snow,and water
    1997 white and yellow, pro circut pipes stage 4 stingers,k&n , boost bottle, duel stage reeds, tors removed, with twist throttel,fly atv handel bars.dg bars,
longmont's Achievements
  1. CHOKE TUBE should of knowen thanks for the help going to clean the carb real good too. Thanks
  2. So I had to replace the idle screw do to loosing it and now bigger probs. She starts after priming the carbs but wont idle and sounds like s!@#. Back fires and sputters. while replaceing the idle screw i had the slides out. Also shees getting gas to the carbs and spark. thanks for the help
  3. I think so
  4. I put a new clutch in my shee. Last time I rode it the clutch cable got real loose. I took It home and took off the clutch cover and the center screw was lose I tightened it back up and the clutch cable was fine. took the shee back to the trail and it did it agen. I no its the screw. what Im I doing wrong that keeps leting it loosen itself?
  5. Shoot me a pm. I'm a modquad and rmatv dealer and can hook you up with a bumper
    And all kinds of bolt on billet accessories and more. Tell me what u want.
  6. I tore into it and the screw looked like it was backed out. I tightened it up to where it should be i=and so far it seems to be working. Thanks for the help I really apprecate it
  7. could the screw that you ajust in the case have come loose. the spring bellow the carbs is barley moving at all
  8. I just had a new clutch put in and everything seemed to be working great. I was out on the track tearing it up let a friend ride it when she came back the cluth cable was way to loose. It wouldent tighten up enough at the lever so I was wondering if it got streatched or maybe came loose in the case. Not real sure please help
  9. choke tube was off fired right up thanks guys
  10. not sure if the bowls are on the right side. How can i tell do I need to pull them back off? Not sure what the choke tube is
  11. I got the black box disconnected and still couldent get her started. Not sure if its cuz its only 15 degrees or what but I probable kicked on it for 20 min.
  12. It does have a air box but no lid. Shee wont even act like shee wonts to start that cant be from jets could it ?. And I put a 310 jet sorry but thanks for the corretion. Whats the prob with a boost bottel
  13. I just got a new shee now it wont start. I pulled off the tors and put a twist throttel on. New duel stage reeds, and a boost bottel. Also put pro circut pipes on. I was told to rejet it with 305 and 27.5. I live at about 5000 feet. Got everything put togeather and there was no spark. If I plug in the thumb throotel theres spark but shee wont fire up at all. Nuthing !When I got her it ran. All stock.
