banshee(911) Posted May 25, 2008 Report Posted May 25, 2008 ok well i went to the drags yesterday and ive got a cheetah cub set up and i got smoked not by one but two stock cylinder banshees ive got the 65 mm cheetah cubs one had cpis the other had some oof well needless to say the bike ran like poo skipped and popped through the whole race i was there all day and finaly @ the end of the races it was time to race and i got spanked dont know why it ran like poo even though it skipped n popped a couple of the races was close what do you think is making it skip and pop some times it runs awsome others it skipps i did go down a size in jets but still no help Quote
sheerider1026 Posted May 25, 2008 Report Posted May 25, 2008 what do you mean by skipping and popping?? whats your compression, fuel and timing??? i went riding yesterday with my 68mm stock stroke cub, and there was this guy with a new suzuki 450 wanting to race.. he was a newbie and basically was saying he knew he could smoke me and wanted to race just so he knew!! well i finally got tired of smoking him and he left with a hurt ego!! lol we even raced on 2 different tracks and he still had no luck.. as far as your skipping and popping let us know some more info on your bike and we can help ya out better that way. Quote
banshee(911) Posted May 25, 2008 Author Report Posted May 25, 2008 (edited) what do you mean by skipping and popping?? whats your compression, fuel and timing??? i went riding yesterday with my 68mm stock stroke cub, and there was this guy with a new suzuki 450 wanting to race.. he was a newbie and basically was saying he knew he could smoke me and wanted to race just so he knew!! well i finally got tired of smoking him and he left with a hurt ego!! lol we even raced on 2 different tracks and he still had no luck.. as far as your skipping and popping let us know some more info on your bike and we can help ya out better that way. its got a 4 degree advanced timing key with a lightened flywheel i dont know my compression its a brand new motor built by local builder it has 18cc domes i did change the plugs yesterday after the first race and it wouldnt start got looking at the wires and the emergency brake switch was un hooked put it back together and it fired right up but i thought i unhooked it a long time ago Edited May 25, 2008 by banshee(911) Quote
banshee(911) Posted May 25, 2008 Author Report Posted May 25, 2008 its got a 4 degree advanced timing key with a lightened flywheel i dont know my compression its a brand new motor built by local builder i did change the plugs yesterday after the first race and it wouldnt start got looking at the wires and the emergency brake switch was un hooked put it back together and it fired right up but i thought i unhooked it a long time ago oh and one cylinder was smoking alott more than the other when was racing Quote
sheerider1026 Posted May 25, 2008 Report Posted May 25, 2008 what do your plugs look like?? are the carbs sync'd?? what type of fuel?? 18cc domes sound like you should be running a good race fuel, depending on the rest of the engine i can't say.. i run 20cc domes and i barely get away with 93 on mine.. Quote
Dave I. Posted May 25, 2008 Report Posted May 25, 2008 is this a brand new motor? Id be careful racing too many times popping and such......what kind of fuel? Pingel? Anything done to the gas cap? did it run good before the new motor? I have no experience with them but ive always heard timing keys are not the most reliable way to advance timing. Id look at the simple things first, but you dont want to eat a piston so take it easy. Quote
banshee(911) Posted May 25, 2008 Author Report Posted May 25, 2008 (edited) is this a brand new motor? Id be careful racing too many times popping and such......what kind of fuel? Pingel? Anything done to the gas cap? did it run good before the new motor? I have no experience with them but ive always heard timing keys are not the most reliable way to advance timing. Id look at the simple things first, but you dont want to eat a piston so take it easy. yes its new motor and i have a billet gas cap no pingel single petcock it ran awsome but had a lil noise and o took it to a diff shop they told me it was piston slap and he talked me into getting cheetah cubs it was faster when i took it to him than when i got it back but he is a reputable builder i posted a video of his bike in the bansheetube under bountyhunter on his stuff but im running 110 for fuel Edited May 25, 2008 by banshee(911) Quote
banshee(911) Posted May 25, 2008 Author Report Posted May 25, 2008 what do your plugs look like?? are the carbs sync'd?? what type of fuel?? 18cc domes sound like you should be running a good race fuel, depending on the rest of the engine i can't say.. i run 20cc domes and i barely get away with 93 on mine.. i dont have a synk tool so im just holding it wot and adjusting them that way Quote
sheerider1026 Posted May 25, 2008 Report Posted May 25, 2008 it sounds like your degree key may have sheared!! i would check it for sure.. also check the pickup gap on the stator.. i had a bad plug cap once that made mine run crappy.. what carbs are you using?? are the carbs also new on this motor?? maybe need to play with needles on them.. first we need to see if it is timing or a jetting problem, or ignition.. what do the spark plugs look like?? Quote
Dave I. Posted May 25, 2008 Report Posted May 25, 2008 I would almost bet you are not able to fill the bowls fast enough. I dont know exactly how those billet gas caps work but everyone i know that runs a cub has removed the internals from the gas cap and drilled it out as big as possible since that is the only vent you have for the tank. If it doesnt vent well it doesnt flow well. Also, you should get a pingel valve, cheap insurance and they really let the fuel flow. Quote
jbooker82 Posted May 26, 2008 Report Posted May 26, 2008 I would almost bet you are not able to fill the bowls fast enough. I dont know exactly how those billet gas caps work but everyone i know that runs a cub has removed the internals from the gas cap and drilled it out as big as possible since that is the only vent you have for the tank. If it doesnt vent well it doesnt flow well. Also, you should get a pingel valve, cheap insurance and they really let the fuel flow. Hell I dont that with my Stock Cylinders. Dual Pingnel and a stock gutted gas cap. Quote
kawiking Posted May 26, 2008 Report Posted May 26, 2008 yep pingle and gas cap... hell no on the degree key !!! get a timing plate !!! what carbs u runnin ?? Quote
kawiking Posted May 26, 2008 Report Posted May 26, 2008 pm oe call jeff and by async tool.. i use mine alot to make sure they are good.. and all my buddies barrow mine... Quote
Keyser Soze Posted May 26, 2008 Report Posted May 26, 2008 Lol degree key works just as well as a plate. As long as your not interested in going more than +5 timing the offset is really nothing to worry about. BUT want to change timing again? Gotta get another key at least $12.00 ...good if you just want to go +4. Quote
banshee(911) Posted May 26, 2008 Author Report Posted May 26, 2008 (edited) yep pingle and gas cap... hell no on the degree key !!! get a timing plate !!! what carbs u runnin ?? 34mm flatslides pjs Edited May 26, 2008 by banshee(911) Quote
