banshee2 Posted May 23, 2008 Report Share Posted May 23, 2008 but what exactly is the powerband and how do u know when u hit the powerband Quote Link to comment Share on other sites More sharing options...
jamebo Posted May 23, 2008 Report Share Posted May 23, 2008 The powerband is the range of rpms when the motor is making and transferring the most power in the curve. A Banshee has a very narrow powerband and comes on all at once. You definitely know when it kicks in! Maybe someone else can explain it a little better than me. Quote Link to comment Share on other sites More sharing options...
banshee2 Posted May 23, 2008 Author Report Share Posted May 23, 2008 The powerband is the range of rpms when the motor is making and transferring the most power in the curve. A Banshee has a very narrow powerband and comes on all at once. You definitely know when it kicks in! Maybe someone else can explain it a little better than me. hey thanks for your help dude it helps a little with explaining it Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted May 23, 2008 Report Share Posted May 23, 2008 a powerband is usually assorted into colors with a bright red being the strongest upon putting this bright red powerband in your banshee motor and running it,one will see many different colors as he accelerates through the gears...brown and possibly yellow are the most typical, assuming you have eaten corn in the past week being the brown color you will see is from the outrageous shit you just took in your pants as you did hit that bright red powerband and the front will jerked off the ground and eyes got blurry...... hope this helps.... Quote Link to comment Share on other sites More sharing options...
banshee2 Posted May 23, 2008 Author Report Share Posted May 23, 2008 a powerband is usually assorted into colors with a bright red being the strongest upon putting this bright red powerband in your banshee motor and running it,one will see many different colors as he accelerates through the gears...brown and possibly yellow are the most typical, assuming you have eaten corn in the past week being the brown color you will see is from the outrageous shit you just took in your pants as you did hit that bright red powerband and the front will jerked off the ground and eyes got blurry...... hope this helps.... lol what the hell Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted May 23, 2008 Report Share Posted May 23, 2008 a powerband is usually assorted into colors with a bright red being the strongest upon putting this bright red powerband in your banshee motor and running it,one will see many different colors as he accelerates through the gears...brown and possibly yellow are the most typical, assuming you have eaten corn in the past week being the brown color you will see is from the outrageous shit you just took in your pants as you did hit that bright red powerband and the front will jerked off the ground and eyes got blurry...... hope this helps.... HAHAHAHAHHAAHHAHAH Back on topic, when you mash the throttle from a lower RPM and it goes from pulling slow to HOLD ON thats when you hit ht epower band, Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 23, 2008 Report Share Posted May 23, 2008 Actually... A powerband is the complete RPM range a motor can run, bottom to top. Banshees are famous for what's called a "Light Switch" powerband. In other words....wait...wait..wait....BAM. And it hits... Broad power band means power all over the RPM range, narrow would be the opposite. Peaky would mean it makes it's usable power in a short/small RPM range (think drag race bikes) There are several ways to describe a bike's actual powerband, but essentially...people use "XXXX" style/type powerband to say where there motor starts to pull in the RPM range...or when it starts to get on the pipe. A "colored powerband" is a long standing joke... Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted May 23, 2008 Report Share Posted May 23, 2008 Actually...A powerband is the complete RPM range a motor can run, bottom to top. Banshees are famous for what's called a "Light Switch" powerband. In other words....wait...wait..wait....BAM. And it hits... Broad power band means power all over the RPM range, narrow would be the opposite. Peaky would mean it makes it's usable power in a short/small RPM range (think drag race bikes) There are several ways to describe a bike's actual powerband, but essentially...people use "XXXX" style/type powerband to say where there motor starts to pull in the RPM range...or when it starts to get on the pipe. A "colored powerband" is a long standing joke... Ya, I was waitin' for that joke to surface....................... The other expainations are good though. Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted May 23, 2008 Report Share Posted May 23, 2008 lol your all killin' me.... gotta love them "colored powerbands"... Quote Link to comment Share on other sites More sharing options...
jrod Posted May 23, 2008 Report Share Posted May 23, 2008 lol your all killin' me.... gotta love them "colored powerbands"... It is alot like a turbo car. Nothing really then just Bam, Off the back of the bike you go. Quote Link to comment Share on other sites More sharing options...
BaNsHeEs RuLe! Posted May 24, 2008 Report Share Posted May 24, 2008 (edited) It is alot like a turbo car. Nothing really then just Bam, Off the back of the bike you go. Check it,I am breaking down to the basics.... It 's like braaaaaaaaaaaaaaaaaaaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAppppppppp And a colored power band is like this, lets use a green one, those are badass bbbbbbbbrrrrrrrraaaaaaaaaaAAAAAAAAAAAAAAAAAAAAAAAAAAApppppppppppp Edited May 24, 2008 by BaNsHeEs RuLe! Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted May 24, 2008 Report Share Posted May 24, 2008 (edited) Check it,I am breaking down to the basics....It 's like braaaaaaaaaaaaaaaaaaaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAppppppppp And a colored power band is like this, lets use a green one, those are badass bbbbbbbbrrrrrrrraaaaaaaaaaAAAAAAAAAAAAAAAAAAAAAAAAAAApppppppppppp OH brown braaaaaaaaaaaaaaaaaaaaaaaaaaaaAAAAAAAAAAAAAAAAAAppppppppp Edited May 24, 2008 by LS1Inferno Quote Link to comment Share on other sites More sharing options...
