pepehaha Posted May 21, 2008 Report Posted May 21, 2008 (edited) Hello, my shee did run well, but now I installed the advanced timing plate, using theproper flywheel puller etc., mounted it together and now shee wont start. Iam getting a good spark. Did I mount it properly, whenI want to advance the timing +4 as reccomended? EDIT:CAN I USE THE RED LOCTITE ON THE BOLTS? Pics: Thank you very much! Edited May 21, 2008 by pepehaha Quote
sycopyroclown00 Posted May 21, 2008 Report Posted May 21, 2008 check and make sure the gap on the pickup is right and recheck everything Quote
ItzaBansheeBitch Posted May 21, 2008 Report Posted May 21, 2008 Make sure you have the Flywheel on the shaft with the Key ( moon key, shear key) locking it correctly. You can have all the spark in the world, but if the flywheel is out of time you will not get combustion. the piston has to be in the correct phase of the stroke. Check that then get back to me. Quote
pepehaha Posted May 21, 2008 Author Report Posted May 21, 2008 So I unmounted the flywheel again, remountedthe timing plate to +4(i figured that it was mounted +1), checked everything and still wont start. When kicking with the killswitch on it makes the same noise aswith the killswitch turned on - it doesn't even start for a sec... Quote
ItzaBansheeBitch Posted May 21, 2008 Report Posted May 21, 2008 Do you still have the T.O.R.S and parking brake on? If so pull that shit off. or just unplug it all and see if shee will start. Quote
pepehaha Posted May 21, 2008 Author Report Posted May 21, 2008 No I have tors and parking brake removed... Quote
ItzaBansheeBitch Posted May 21, 2008 Report Posted May 21, 2008 Have you pulled the plugs? Are you getting gas? plugs will be wet if you have kicked the shit out of it with no ignition. Quote
pepehaha Posted May 21, 2008 Author Report Posted May 21, 2008 Yes the shee run well before I changed the plate. I pulled the plugs and they were very wet.. What to do now? Quote
ItzaBansheeBitch Posted May 21, 2008 Report Posted May 21, 2008 (edited) Is your air filter clogged? 2-strokes MUST fire if they have spark and fuel. They are super simple and only have a few problems that can prevent combustion. Let the plugs dry out before you reinstall them. Pull your air filter off and try to start it again. Edited May 21, 2008 by ItzaBansheeBitch Quote
Keyser Soze Posted May 21, 2008 Report Posted May 21, 2008 Check the flywheel key? May sound stupid but ive forgot to put it back in before...... Quote
Snopczynski Posted May 21, 2008 Report Posted May 21, 2008 Pickup gap? Did you connect the yellow stator wire to yellow on the harness, and the black to black on the harness? Flywheel key properly installed. Ground on timing plate hooked up correctly? Did you hit the flywheel or drop it at all? Did you drop the stator at all? Quote
RollinRhino Posted May 21, 2008 Report Posted May 21, 2008 Every post on here is right. Said it yourself, ran good before you put this on. Has to be something simple. Check the ground is where I would start. The plugs will be wet if no fire is produced. Dry them off and leave them out and kick it over instead with them out and see if they spark at all after you check all the connections from the harness. You either plugged something in wrong, or you are not grounded. Quote
pepehaha Posted May 21, 2008 Author Report Posted May 21, 2008 (edited) Thank you all very much. You can officially call me an idiot now :-) Sure it was a simple stupid problem... When I was washing my shee I taped the airbox to not allow any water in. Guess what :-) I didnt remove the tape so no air for the motor = no good :-D Than I was happy I found the mistake but still didnt fire up. Guess what, I forgot to plug one spark plug cap... LOL. But when I finally fired it up, I warmed it up and took for a little ride. Wow, I couldn't belive the difference! Now it's easier to wheelie, and also I can wheelie in 3rd gear by just pushing the half throttle... I don't think it added somuch low range, but huge midrangeand top boost! Definitely worth the money andd work, I highly reccomend it! Once again thank you guys! Edited May 21, 2008 by pepehaha Quote
jamebo Posted May 21, 2008 Report Posted May 21, 2008 Well I'm glad you found the problem.... I did something similar one time. I usually slide a sandwich bag over my snorkel when washing it and forgot to remove it. It didn't keep it from running because I have an outerwears lid, but I didn't discover it for a couple of days. Quote
