yes the nipple and yes tighten the nipple b/4 you lift the pedal
and don't pump the pedal real fast do it slow and controlled so you don't froth the fluid
pump five or six time slowly, crack the nipple (bleeder) while holding pedal down , tighten , repeat
there cake to bleed fill the top end put the cap back on, pump the pedal a few times hold the pedal down crack the bleeder and repeat till u have a pedal,
or get a long clear hose that fits on the bleeder , crack it a bit then slowly suck a little till u get fluid and then do the above...
dont forget to keep cking the fill so it doesnt go dry
Everything i have is from an 01
case with trans $350 OBO
Virgin Juggs no studds need bore or really good hone $250 OBO
coil $50 OBO
Harness $60 OBO
2 CDI'S $65 Each OBO
REAR BRAKE SETUP WITH 10+ BRAIDED HOSE
STOCK FRONT SHOCKS $100 obo
stock rear shock $100 obo
front a arms $100 obo
stock tail light $20 obo
kill switch $25 obo
2 stock rads
1 no cap both with hoses $50 obo each
will post pix later this weekend
