ok well ive had this problem b-4 and it just went away now its back and ive got a race on the 24th man this sux i just got it out of the shop for the same reason it didnt do it for id say a day then came back after i got it from shop it comes and goes not sure what it is ive replaced the kickstart idler gear and its still there it is hurting the performance of the bike when the noise is gone it runs awsome but when it comes back it looses a great deal of power and you can really hear the rattle right behind the kickstarter no its not the kicker its self HELP
How exactly does it run when it isn't running good?
it will not peek out like something is slowing the motor
Remove all the clutch plates and make sure none of the fibers are shattered.
ok so i went and tore my clutch apart and no broken plates but i checked my clutch basket and there is a lil play i can grab the basket and move it a lil bit twisting and pulling
Edited by banshee(911)
if i dont need new cases then thats 350.00 for a port job :biggrin:
got looking at my kiker idler gear and it looks to me that its wore on the inside like its hitting on something well im trying to locate an electrick impack wrench to pull my clutch basket ill post more later
Hey! 911, check your pressure plate, pull it off the spline and turn it a little bit :wink: . I think that's your problem.
with the motor running and putting my hand on the kickstart and reving the motor you can feel the kicker pull back
on the preasure plate the rod that goes in sapose to b loose?
well i guess no one can figure it out ive posted this be-4 nope no help yet c-mon theres gotta b some one that can figure it out
it sounds like your kicker gear isn't disengaging all the way. do you have that little clip in the right slot in the case? get out your clymers and double check.
did that
did that
ok well i took it apart yesterday and i noticed my preasure plate rod was loose really loose so i tightend it and the noise didnt go away completely but it got alot quieter then my nephiew rode it just to c if the clutch was slipping and he brought it right back and the noise was louder again so today i took it apart again and the rod was loose again so this time i locktighted the damn thing hope it fixes it
well thanx for all the in put oh and the preasure plate only goes on 3 ways lining up the arrows but i did put it on a diff arrow this time again thanx, Ray
