The only difference between the two are the "BR" plug is suppose to help with resistance of electrical noise I believe (the R in BR stand for Resistor/Resisted). They are suppose to be better in vehicles so that you don't hear the electrical noise through the radio, etc.
So no their isn't much difference between the two other than what I mentioned. You will be safe with either spark plug :thumbsup:
and they are for different heat ranges br7es is the hottest i belive then br8es is the middle then br9es is the coolest plug between the three.
There's a whole bigger heat range than that...low as 6 and high as 11 or so that I know of.
If you're running a 100% stock ignition, BR or B plugs are fine. When you start to get into aftermarket coils, aftermarket CDIs they may have a preference on Resistor or not.
  • 1 month later...
YFZ350 Banshee 87-01 .028 NGKB8ES
YFZ350 Banshee 01-02 .032 NGKBR8ES
i saw this somewhere the .028 and .032 is the gap...what symptom will i get if i put the one in with the wrong gap....couldve had .028 and replaced with a .032 or had .032 and replaced with a .028
also 87-01 is the year same with the 01-02 thanks in advance...
