atvfreestylekid Posted April 8, 2008 Report Posted April 8, 2008 I just installed a set of yfz shocks on the shee and trying to get it all tuned right. Do I use an air compressor on the bottom of the shock rezys or is it for somthing other than air? Quote
airtite Posted April 8, 2008 Report Posted April 8, 2008 I just installed a set of yfz shocks on the shee and trying to get it all tuned right. Do I use an air compressor on the bottom of the shock rezys or is it for somthing other than air? I wouldnt use an air compressor on there....... have you adjusted the compression and rebound screws? and what about the preload adjustment? I had mine revalved on the 450 and that made a huge improvement over stock. Quote
atvfreestylekid Posted April 9, 2008 Author Report Posted April 9, 2008 I wouldnt use an air compressor on there....... have you adjusted the compression and rebound screws? and what about the preload adjustment? I had mine revalved on the 450 and that made a huge improvement over stock. The reason I'm asking is there is no pressure in the rezys. What do i need to put in them? and where do I get it? I have a race on the 20th and realy need to get these set up right by then. Do They have to have pressure in them? Thanks -Josh Quote
LS1Inferno Posted April 9, 2008 Report Posted April 9, 2008 its nitrogen. you can just go to the local air gas, praxxair or wherever and get a small tank and use a regulator so you can keep making changes to get it right. Quote
