I just installed a set of yfz shocks on the shee and trying to get it all tuned right. Do I use an air compressor on the bottom of the shock rezys or is it for somthing other than air?
I wouldnt use an air compressor on there....... have you adjusted the compression and rebound screws? and what about the preload adjustment? I had mine revalved on the 450 and that made a huge improvement over stock.
The reason I'm asking is there is no pressure in the rezys. What do i need to put in them? and where do I get it? I have a race on the 20th and realy need to get these set up right by then. Do They have to have pressure in them? Thanks
-Josh
