blueboy22 Posted March 21, 2008 Report Posted March 21, 2008 well i finally decided to tear down my motor to find the reason the right side wasn't running.. sadly i found the piston seized in the cylinder thinking that was the end of my problems i didn't think it was too bad then somehow i looked down to see theres a very nice about 1/2 inch by 2 inch crack in my cases should i just part it out and cope my loss or be better to rebuild it? what would be cheaper? Quote
jmd0346 Posted March 21, 2008 Report Posted March 21, 2008 Damn that stinks. Well the piston may have been gualling(sp?) but it wasnt seized. It wont run if it was seized up. Where is the crack? I cant imagine how you had a hole in the case and have to tear it down to notice it. Give us some more detailed info if you want help please. Quote
blueboy22 Posted March 21, 2008 Author Report Posted March 21, 2008 well the right side wasn't running and i went through everything people suggested and nothing worked so i took my head off to see the piston stuck.... then i took of the cylinders to take out the broken piston then noticed the nice big crack in it.. Quote
KaosBanshee44 Posted March 21, 2008 Report Posted March 21, 2008 Just get matoon cases :biggrin: haha naw you can really just get a set of old cases and rebuild it. Quote
inthemail Posted March 21, 2008 Report Posted March 21, 2008 perhaps you can have them welded? ask local shops if they specialize in welding CAST ALUMINUM. feel out your answer, if it dont sound right dont let them weld your shit. if the crack is a hairline you might be able to get away with powdercoating them. i dont know how far pc would go as to seal cases but i imagine if the pc was done good it could work since its resistant to oil and gas. Quote
kawiking Posted March 22, 2008 Report Posted March 22, 2008 pm NYUK ... he may have a extra set to sell. ive had a extra set for about a year in a half, its nice to know u have a back up , just in CASE. (lol) Quote
dajogejr Posted March 22, 2008 Report Posted March 22, 2008 post up a pic of the case. If it's not a load bearing part of the case, more than likely it can be welded and ground down. They're pretty resilient, believe it or not... Even if it needs a crank rebuild, fresh bore, welded cases and new pistons, you're only looking at 300 to 500 bucks. So...decide if it's worth it to part it or fix and keep it. There are so many used, quality parts for these things out there....it can be done cheaply and easily... Quote
