alright so i have everything tore down and the motor out of my banshee it looks as if it needs new cases, crank, and set of pistons for sure...what else should i do besides that? bored and hone?
i'm not sure if i'll do all this work myself but where should i send my stuff for the rebuild?
also is it even worth building or should i just buy a used running motor off ebay or something?
i also might look into getting some porting done if everythings not to pricey...which brings me to my next question...how much should i be lookin to spend at a shop with all that listed above? thanks!
pro design head with 20cc domes,chrome t-5's, k&n 2 in 1 filter with outerwears,chrome lsr +2 axle, pro taper bars,shock covers, chrome grab bar, razrs all around,digital speedometer
heres the story the piston was siezed in the motor and theres a crack in the cases ($300-500) worth of work if i dont get it sold or traded i'll end up just rebuilding it
i need to trade for a daily driver car (that gets good gas milage)
or sell it for $2000 obo
and if i get enough interest to part it out i will
http://i107.photobucket.com/albums/m282/qu...22/S6000133.jpg
i'm located 10 minutes from cincinnati, ohio
i can drive to meet up to a reasonable distance
thanks
well the right side wasn't running and i went through everything people suggested and nothing worked so i took my head off to see the piston stuck.... then i took of the cylinders to take out the broken piston then noticed the nice big crack in it..
well i finally decided to tear down my motor to find the reason the right side wasn't running.. sadly i found the piston seized in the cylinder thinking that was the end of my problems i didn't think it was too bad then somehow i looked down to see theres a very nice about 1/2 inch by 2 inch crack in my cases
should i just part it out and cope my loss or be better to rebuild it? what would be cheaper?
idk if i worded it right or not but its the cables coming off the top of the carbs that i need to remove...anyone explain to me how to do this? thanks..
tried switching it to reserve and nothing still got the same prob compression does seem a bit lower just kickin it over...so what do i go through for that pull the head off and check the internals?
it was running great started on first kick and no bogging or studdering through the powerband, it has t5's coolhead with 20cc domes k&n and has been dyno jetted as far as performance. oh and i'm running open lid airbox
changed the plugs today fired right up but the right sides still not kickin in and vibrates everything on throttle...pulled the plug again and checked it and it was a lil wet....where would the airleak be coming from...? anyother ideas?!
took everything apart and looked at the reeds last night and their all fine....anything else it could be? i remember a vibration when i started it last and noticed the right side wasn't running...could this pinpoint anything? just a spark plug or should i pull the head off and check everything?
