alright so i have everything tore down and the motor out of my banshee it looks as if it needs new cases, crank, and set of pistons for sure...what else should i do besides that? bored and hone?
i'm not sure if i'll do all this work myself but where should i send my stuff for the rebuild?
also is it even worth building or should i just buy a used running motor off ebay or something?
i also might look into getting some porting done if everythings not to pricey...which brings me to my next question...how much should i be lookin to spend at a shop with all that listed above? thanks!
pro design head with 20cc domes,chrome t-5's, k&n 2 in 1 filter with outerwears,chrome lsr +2 axle, pro taper bars,shock covers, chrome grab bar, razrs all around,digital speedometer
heres the story the piston was siezed in the motor and theres a crack in the cases ($300-500) worth of work if i dont get it sold or traded i'll end up just rebuilding it
i need to trade for a daily driver car (that gets good gas milage)
or sell it for $2000 obo
and if i get enough interest to part it out i will
http://i107.photobucket.com/albums/m282/qu...22/S6000133.jpg
i'm located 10 minutes from cincinnati, ohio
i can drive to meet up to a reasonable distance
thanks
well the right side wasn't running and i went through everything people suggested and nothing worked so i took my head off to see the piston stuck.... then i took of the cylinders to take out the broken piston then noticed the nice big crack in it..
well i finally decided to tear down my motor to find the reason the right side wasn't running.. sadly i found the piston seized in the cylinder thinking that was the end of my problems i didn't think it was too bad then somehow i looked down to see theres a very nice about 1/2 inch by 2 inch crack in my cases
should i just part it out and cope my loss or be better to rebuild it? what would be cheaper?
idk if i worded it right or not but its the cables coming off the top of the carbs that i need to remove...anyone explain to me how to do this? thanks..
