motooko Posted March 17, 2008 Report Posted March 17, 2008 my banshee will not suck in gas through the carbs..... carbs r cleaned ... brand new v force reeds.... brand new top end... it just doesnt seem to wanna suck gas through.... the carbs are fiilled w gas and floats are reset .... i culd shoot a little ether in the intake and she fires right up.... please help me u guys seem to know urshit Quote
shee rips Posted March 17, 2008 Report Posted March 17, 2008 first off, i wouldnt make a habit of running it on ether, because theres no lubrication getting to your engine that way. :ermm: i dont know about the no gas issue though Quote
motooko Posted March 17, 2008 Author Report Posted March 17, 2008 hahah duhhhhhhh lotta help u were .. it was just a test to c if it wuld run and its def a fuel problem Quote
Screaming Yellow Zonker Posted March 17, 2008 Report Posted March 17, 2008 does the fuel flow out of the petcock? does it make a difference if it is on reserve or not. Is the fuel on? Is there gas in the tank? There are two filters on the petcock in the tank. you might have to remove the petcock and clean the filters. Quote
shee rips Posted March 17, 2008 Report Posted March 17, 2008 hahah duhhhhhhh lotta help u were .. it was just a test to c if it wuld run and its def a fuel problem i was just saying so that you dont come on here with your shit blown up from nothing but ether going through it Quote
hylander88 Posted March 17, 2008 Report Posted March 17, 2008 my banshee will not suck in gas through the carbs..... carbs r cleaned ... brand new v force reeds.... brand new top end... it just doesnt seem to wanna suck gas through.... the carbs are fiilled w gas and floats are reset .... i culd shoot a little ether in the intake and she fires right up.... please help me u guys seem to know urshit well I give my 2 cents...your getting fuel in the carbs...they just might be out of sync..and adjustment..since it will start with ether...thats how mine was... Quote
r_flagel222 Posted March 17, 2008 Report Posted March 17, 2008 check to see if gas and oil seperated in tank and or carb bowl..... mine did that last week. its cold in michigan! Quote
bansheejoel Posted March 17, 2008 Report Posted March 17, 2008 hahah duhhhhhhh lotta help u were .. it was just a test to c if it wuld run and its def a fuel problem he was just trying to help, you dont have to be a dick about it. Quote
