FireHead Posted March 8, 2008 Report Posted March 8, 2008 could it be the carb choke plunger because i am having a hell of a time finding the dam leak :ermm: . could the the head gasket or base gasket be blown if the mechanic did not torq the head down properly No on the choke plunger. Possibly on the baske gasket.......... :geek: Quote
rubberneck Posted March 8, 2008 Report Posted March 8, 2008 Switch the carbs from side to side and see if the problem follows the carb or stays with that cylider. On stock carbs you will have to cap off the bosses that the choke tube goes between. Or do a leak down test like was suggested and that will tell you if you have an air leak for sure. Quote
David Keith Posted March 8, 2008 Report Posted March 8, 2008 Switch the carbs from side to side and see if the problem follows the carb or stays with that cylider. On stock carbs you will have to cap off the bosses that the choke tube goes between. Or do a leak down test like was suggested and that will tell you if you have an air leak for sure. Are you sure the choke cross-over tube is connected? I left mine off once & it acted like what you are describing. I had to swallow my pride & admit I overlooked what should have been obvious. Quote
desert nut Posted March 9, 2008 Author Report Posted March 9, 2008 Are you sure the choke cross-over tube is connected? I left mine off once & it acted like what you are describing. I had to swallow my pride & admit I overlooked what should have been obvious. dude no offense but is you can start your shee w/out the cross over tube you aea a bad a$$$ but dude i know a bit about 2 stroke cuz i can READ aint no pride swallowing Quote
FireHead Posted March 9, 2008 Report Posted March 9, 2008 dude no offense but is you can start your shee w/out the cross over tube you aea a bad a$$$ but dude i know a bit about 2 stroke cuz i can READ aint no pride swallowing I have been able to start my red bike without the crossover tube on several occasions. Beer or Yeager was usually involved though. Quote
desert nut Posted March 9, 2008 Author Report Posted March 9, 2008 I have been able to start my red bike without the crossover tube on several occasions. Beer or Yeager was usually involved though. dude too funny :yelrotflmao: yup i guess you are right if there's a beer theres a way :beer: Quote
akita8 Posted March 9, 2008 Report Posted March 9, 2008 Check you wiring harness that comes from the CDI on the rt aft side and make sure it has'nt melted to your pipe. Quote
desert nut Posted March 27, 2008 Author Report Posted March 27, 2008 Check you wiring harness that comes from the CDI on the rt aft side and make sure it has'nt melted to your pipe. new wire harness should i just buy complete new topend gasket set because the guy who put it together the first time did not torq priperly then i had it retoqed properly but maybe it blew a base gasket Quote
hylander88 Posted March 29, 2008 Report Posted March 29, 2008 could it be the carb choke plunger because i am having a hell of a time finding the dam leak :ermm: . could the the head gasket or base gasket be blown if the mechanic did not torq the head down properly it could be the choKe plunger ..O ring on it could be warn out...new plunger for it is about 40 bucks...the O-ring is metric if you just want to replace that if you can find them... Quote
