desert nut
Everything posted by desert nut
  1. no tores just synced them last week
  2. shee has a neww 65 mm bore new carb kit neww wire harness newww coil newwww cdi newwwww stator newwwww plugs but it still misses on left cylinder swithed plug and plug wires still same put choke on runs no miss but runs crappy give it high revs seems to go away but go low revs still misses man i need help in a bad way :: going loco :yelrotflmao: glamis season is here :beer: and i need my shee
  3. might check out ground by cdi or check flywheel
  4. new wire harness should i just buy complete new topend gasket set because the guy who put it together the first time did not torq priperly then i had it retoqed properly but maybe it blew a base gasket
  5. i have a extra piston weisco prolite 65mm band new w/ristpin and rings make me an offer :cool:
  6. dude too funny :yelrotflmao: yup i guess you are right if there's a beer theres a way :beer:
  7. dude no offense but is you can start your shee w/out the cross over tube you aea a bad a$$$ but dude i know a bit about 2 stroke cuz i can READ aint no pride swallowing
  8. could it be the carb choke plunger because i am having a hell of a time finding the dam leak :ermm: . could the the head gasket or base gasket be blown if the mechanic did not torq the head down properly
  9. ok the lean condition due to air leak in system or jetting or both
  10. i can nit find prob. when i put half choke on it stops to backfire when warm can it be the carbs or it still may be an air leak i don't understand why it seems to work fine when choke is half on
  11. well i checked but i can not find the fn leak :: it gets warm and seems like the left side backfires but when i pull choke for a few seconds it looks like it sucks some fuel from left side to right on through carb cross over tube the i put choke in and it fires fine for a but :verymad: could it be the choke plunger :shrug: i don't fn know just throw'n it out there can some one help????? :: :: ::
  12. ok will check thank you guys for help without this forum i would be lost
  13. just had bike redone topend 65mm bore checked everything so i thought but when bike warms up on left side it backfires. when the choke is on it seems not to do it as much can anyone help me!! i am just about done with this piece ! it has great compression reeds are good new carb kits new crank seal :mad: whats next :: ::
  14. do you still have the bumper if so do you have paypal account
  15. thanks i will but before i rebuilt it it was smokin about the same
  16. JUST CHECKED TO SEE IF THEY ARE BAD PER CLYMER BUT THE WERE FINE BUT IT IS SMOKIN BAD ON RIGHT SIDE
  17. I HAVE A 1996 BANSHEE NEW TOP END 65MM BORE CLEANED CARBS HAVE 300 MAIN AND 30 PILOT JET HAVE NOT COMPLETELY BROKE IN, GREAT COMPRESSION BUT IT IS SMOKING LIKE A CRACK HOE :: ON RIGHT SIDE SEEMS LIKE IT IS PASSING ALOT OF AIR ON EXHAUST ON RIGHT SIDE I NEED HELP :sick: CHECKED REED AND THEIR IS NO SPACE I AM ABOUT TO BLOW THIS UP :mad:
  18. 150 plus shipping or looking to trade aftermarket banshee parts
  19. i have a all kinds of stock banshee parts all stock front a arms front shocks front rotors and calipers rear shock front brake lever with res. stock coil swing arm yfz450 a arms set rear race cut fenders need paint front fenders cut radiator cover and grill anything else your lookin for just ask i'm just tryin to cleen my shop "garage" :cool:
  20. dude i'm in brawley ca. socal you know i,'m there see you all i'll be at the tree line off of vendors flats :cool:
  21. the person who owned before me damaged the pistons and replaced the pistons without repairing the cylinder :mad: he was a dumbass :: but of course he did not let me know when i bought it i just need to know what size jets to use for a 65mm bore
  22. this is the first time i blew up my shee , shee is a virgin i have to cut it to a 65.00 cuz it wuz bad i have toomey t6's stock carbs k&n filter kit no air box lid. i do not know what jets i should use. right know i have 300 main and 33.5 pilot can any one help???????
  23. check the pilot jet on that side i had that prob it is gonna be a carb issue in my case it was a missing pilot jet replaced now it runs f'n great
  24. send me pic of bumper i am interested [email protected]
  25. i have a coil in great condition 45.00 shipped usps
