overhauler Posted February 29, 2008 Report Posted February 29, 2008 hey guys say i baught a 4 mill stroker crank... what would i have to get done to my cylenders and what pistons should i run?.. im looking to make the shee go pretty fasty without going realy retarded.... what you guys think?... what kinda machining do i need to get done ... Quote
Wildcardracing Posted February 29, 2008 Report Posted February 29, 2008 You have two options. A)Run a spacer plate between the jugs and case Have it ported and the head/domes cut for the increased stroke. If it's a long rod you'll need to run wiseco 795 pistons. Having it ported for the stroke is the best option because it will run stronger, have less gasket surfaces for potential air leaks and nobody can look at it and tell it's stroked. :thumbsup: But, it is pricey compared to the spacer plate. Quote
atvfreestylekid Posted February 29, 2008 Report Posted February 29, 2008 hey guys say i baught a 4 mill stroker crank... what would i have to get done to my cylenders and what pistons should i run?..im looking to make the shee go pretty fasty without going realy retarded.... what you guys think?... what kinda machining do i need to get done ... All you have to have it Wiseco 795 pistons, stroker spacer plate, and the crank you already have. You won't see much with just the crank. I say do the spacer for now and the on your next re-build, spend the big bucks on porting and head mods. Quote
overhauler Posted March 3, 2008 Author Report Posted March 3, 2008 How much $$$ you got? i have about... 10 grand to throw at this old girl Quote
Bansh-eman Posted March 3, 2008 Report Posted March 3, 2008 10 grand??? fuk that spacer plate... do it right! get it ported, buy a coolhead, timing plate, reeds carbs pipes clutch swinger all the goodies... Quote
Animalman294 Posted March 4, 2008 Report Posted March 4, 2008 If I had 10 grand to throw at my bike I would really have a nasty machine, not that I don't now, but it would be really wicked nasty................. Quote
Bansh-eman Posted March 4, 2008 Report Posted March 4, 2008 If I had 10 grand to throw at my bike I would really have a nasty machine, not that I don't now, but it would be really wicked nasty................. if i had 10 grand to throw at my bike i wouldnt be throwing it at my bike, id be paying off some bills lol Quote
FireHead Posted March 4, 2008 Report Posted March 4, 2008 if i had 10 grand to throw at my bike i wouldnt be throwing it at my bike, id be paying off some bills lol I didn't know you had a billing system setup with the pirate hookers yet.............. :biggrin: Quote
nayr742003 Posted March 4, 2008 Report Posted March 4, 2008 send it to fast and have jeff completly rebuild the thing totally wicked. do it once and do it right....!!! Quote
Wildcardracing Posted March 4, 2008 Report Posted March 4, 2008 10 GRAND!!!!!! hell, toss the stock cylinders on the shelf and get yourself a cheetah top end kit for the 4mill then some 35mm carbs, CPI inframes and an upgraded clutch then throw the other 5 grand into suspension, chassis and appearance. Quote
