hi all,
i need some help on which size jets to get. here is my setup:
+4 crank
dune/stroker port job
bored jugs 65.5mm
noss head 21cc cut domes
+4 timing
stock reeds
bored stock carbs 27.5
i live in california and glamis is just below sea level at -56 ft.
what size mains and pilots should i go with? do you think it would be better if i went with a jet kit? any help would be great, thanks.
mod wise i would say somewhere around 330 for mains, give or take some, i am not to good with port work jetting and low elevation, and deffinatly 27.5 or 30 pilots, thats my close estimate
hi all,
the pilot jetts are stock which are 25. the mains are 280 which came with the t6 kit. these jets worked great for the stock crank with pipe kit, but i am clueless which jets to use now with my new mods, please help, thanks.
hi all,
Contact the builder who did your portwork, he should be able to get you close. Porting is kinda the wild card when it comes to jetting because no two builders port jobs are the same.
