I Flat track race, wanna get sway bar outa harms way... we run on a 1/8 mile "bullring'' and i have desroyed 2 last season. the ony issue i have is the bar hits the a arm the way i wanna put it on. i have a all 4 jarms and spindles. has anyone tried to make it work on a a arm frame?
From what i've been told J-arms eat ball joints. You could just make some with replacable ball joints. you can get them cheap at parts stors and like So-Cal Im going to be making some A-Arms real soon
thanks for the info..... i am planing on using heims fittings on the end of the j arms to be able to adjust camber for different tracks. i am pretty good with a welder when i gota be. i am wondering if anyone has made the switch from j to a arms?
I know that people have switch from j arms to a arms but I don't know of anyone that has gone the other way, j arms are weaker, I would try to find a different approach to installing your sway-bar.
I started out with a J-Arm frame and upgraded to an A-Arm frame because the J-Arms do not provide the same level of stability and strength that A-Arms do. I would find a different way to mount your sway bar. I doubt you'll be happy with J-Arms. Especially after the first time you bump into something and end up having to replace the arm.
I have also switched to A arms from J arms and I doubt you want those for racing, You could probably make them work but from my experience with them they are JUNK.
seems as if i gota find someone to shorten my bar and respline it.... any takers? i have called every machine shop within 200 miles and noone has the tools to do this.........sad but true.
Post some pics of how you had it mounted, maybe someone will have a better idea. Is your bar wider than the distance between your wheels??
i have a from lowering bar it moves the shock almost straight up and down.. by doing this it makes the shocks the same width as the bar and there is no way to put it on... as of now i have it moubted way up high on the stock shock mounts with the arms sticking forward. the a-arms have tabs welded on them. i have picks but dont know how to resize and they wont post in the size they are... help and i will post them..
