NN2 Posted February 4, 2008 Report Posted February 4, 2008 I just bought my first Banshee and wanted to know what kind of gains I'd see with a 4mil crank. As it sits right now it has a .20 over bore, port and polish job, stock head cut/re-chambered, Hot Rodz crank (stock stroke), weseco pistons, V-force 3 reeds, Trinity 2 into 1 35mm Keihin carb (airbox removed), Duncan Mid-range pipes with silencers. I've been tearing around on it and it is a blast but can definately handle more power. If it is worth it then can I just have the cylinders re-ported for the crank or is the porting a one time deal?? Quote
00tbanshee Posted February 4, 2008 Report Posted February 4, 2008 i think it is like a 7% gain but depends on who you get to port it for the 4mil cause maybe they could get somemore gains out of the port work. Quote
moneybags Posted February 4, 2008 Report Posted February 4, 2008 Get ride of that 2 into 1 carb setup. You would probly see a 7% gain on the top end by swiching to a dual carb set up. What kinda of port job did you get? Quote
kawiking Posted February 4, 2008 Report Posted February 4, 2008 where do u live and who did the porting ?? what kind of riding are u doing. Quote
NN2 Posted February 4, 2008 Author Report Posted February 4, 2008 The 2 into 1 carb setup was that way when I got it. I was told the porting was done at a shop towards the Grand Rapids area called R&B. Most of my riding will be trail riding and a few trips to the dunes. Quote
dajogejr Posted February 4, 2008 Report Posted February 4, 2008 Bob of R&B is actually out of Lansing area, not quite Grand Rapids. He's a helluva nice guy... Sometimes, shops don't want to work on other's cylinders. So...if you're pretty sure R&B did the port work, I'd let them do it again for the 4 mil stroker. Before I'd tell you to ditch he 1 into 2 setup, I'd answer Kawi's quesitons of where you ride and what type? Honestly, it wouldn't be a stretch to change carbs, modify porting and get a 4 mil stroker crank and get another 10 to 20% increase out of it. However....it depends on what "kind" of power you're looking for!!!! Bob @ RB Porting is 517-388-3662 Quote
