ok guys im looking for some info, i made a leakdown tester useing the how to guide RNBrad had on here awhile ago and i just can find anything to use as plugs to plug my intake and exhaust. has anyone tried anything else out there to plug there port off that's air tight? post some pics give me some wacky ideas. i have spent about 3 hours grooming the hardware stores around here looking for something but just can find the perfect piece.
http://www.bansheehq.com/forums/index.php?...5&hl=rnbrad
For the intake use a peice of round steel rod the right dia to fit in the carb boots and cut a couple of 3/4 slices off it. Drill thru and tap one to accept a barb fitting. The exhaust I use two expanding rubber plugs from the local hardware store.
Home Depot has 'em...the exhaust plugs.
Look over by where you'd buy the rubber chair leg thingies... They slide over the chair leg not to mar a wood floor, etc.
I think the Inside Diameter of the exhaust is roughly 45mm or so...if that helps.
Yeah, Dave has been using those as butt plugs for awhile now. :miner:
Well...I didn't want to say it, but....Firehead did pass them on to me when they got too small for him. So....he uses XXXXL But plugs....batteries not included.
That would still make you the guy using "used" butt plugs,,,,,,,,,,,,,I am not sure which is worse. :confused:
here is a few pics of my homemade leakdown tester. I got the plugs from Ace hardware, they are in the bolt and screw alse's.
lol thats allmost the same kinda leakdown tester im makeing. you will have the excuse my spell ing im alittle drunk. well alot drink accualy. heres a pic of my valve and gauage. im going to turn my compresser down and just shut the valve ff when it gets to 10psi.
haha yup pretty much the same concept. i said screw buying a medical hand pump thing and just made one to work with the compressor with some fittings laying around my shop. your on the straight and narrow now, hope she holds!
finally got it all pieced together heres some pics. got some plugs for my stock intakes and my buddys 35mm. i threaded them so i can just interchange them. oh yeah and the plugs for the exhaust are table leg covers. i forget who mentioned that but thanks alot i found them right away
