Ive read around on here that g-force is a good brand axle for the money from Rocky Mountain. Im curious to know if its worth the money to get a wider axle now that my front end is wider from the a-arms. I mainly use this for sand dunes. I havent taken it out yet since the a-arms but will do so this weekend and see what it feels like. Anybody have any opinions or experience with wider front end but leaving the rear stock?
if you where track riding id say yes but for dunes and all that i run mine at stock width. I have an RPM Dominator axle. got it for 200 off ebay used. it goes to like +4 but im running it stock
You will notice a big difference when you make the rear end wider in the dirt. The bike seems to track better with a wider rear end, along with being harder to tip over. The rear end doesn't want to slide around as much when it is wider
I recently just purchased some yfz450 front shocks with arms.... and i have had this question to.... Do i really need to widen the axle?
the answer to that or what i heard is If you don't widen the axle but you have longer arms It will affect the steering otherwise and make the bike push in turns.
I also just got a durablue for 100 bucks! but here is the chart for all axles on the market fromt best to worst
http://atvsuspensiontech.com/files/axle_test_results.pdf
and as you can see rpm dominator II did the best
Edited by 714banshee380
I don't have a g force, but have read many very very good things about them. apparently cant beat them for the price.
