Well today I got my new chain put on wanted to go for a ride but it's running like shit and Idk whats wrong with it. Ok so with full choke on it will idle fine if you keep it running like always. half and no choke the left cylinder starts shutting on and off. if you rev it the left cylinder will kick on after about half throttle or so. When you ride it it will bog until about half throttle then it will kick on and rip but you have to stay on it if you let the R's drop below half the left cylinder will shut off and bog. Any questions you need to ask to help me figure this out go ahead and ask and I'll answer them. Thanks for any help.
  • Replies 39
  • Created
  • Last Reply
Top Posters In This Topic
sounds like u have a pilot jet stopped up my friend, take it out, shoot it with some carb cleaner, air pressure, or a thin wire from a wire brush to run through it works good.. should fix it..
Edited by sheerider1026
Oh I did forget to mention that it also pops and backfires and the weird thing is is that I noticed but just remembered the first time it poped it was out of the right cylinder now I don't know which one it's popping out of I just know that it is. if that changes anything?
mine was doing EXACTLY the same thing just yesterday so i went to my local yamaha dealer and with some help from this site i replaced the plugs cleaned out my carbs really well made sure my choke tube was hooked up (which it wasnt before i took off the carbs) and put new gas and oil in now she runs like a raped ape....i would say try new plugs check your pilots and check your choke tube worth a try
I cleaned the plugs not sure if that'd help but I couldn't find my extra's and I just threw my boost bottle on today and I didn't notice the choke tube being disconnected but it's possible.
bosst bottles are only good to be meslted down and made into ashe trays in my opinion, they just end up cracking the intake boots and causing a lean condition due to an air leak.. just my .02.. like everyone said, clean those carbs, make sure the choke tube is on, and new plugs, should be good to go.
Will the boost bottle help though? idk because I didn't get a chnace to test it out lol
ok well thanks to everyone for your help I'll hopefully get to doing all this stuff sometime soon depending on the weather and I'll let you know how it turns out.
K so I got some more info. Went out and started full choke second kick ran both cylinders. Half choke ran both cylinders.Off choke ran both cylinders got real happy :) lol ran for a litle bit like that started reving ran both. then started shutting off again got pissed held in one spot but slowley moved up in r's and shot a blue flame out the left side let off started free reving again and it bogged till it shut off??? I'm at a loss please help
If I switch wires it should it do it on the other side then I'd know thats my problem right?
No I haven't gotten to do anything yet because it's too cold out lol but when I do 'll try out everyones ideas and let you know how it goes.
Hears some advice for you bud. Clean out the carbs before you blow the thing then new plugs. I had a spark plug that wood spark just fine until i started the motor then i wood not run at a idle of half throttle. It wood pick up and go on when i pined it tho. But don't run that banshee until you get the carbs cleaned because you don't want to lose that banshee because it went lean.
Chevshee
