F.BEJARANO Posted January 15, 2008 Report Posted January 15, 2008 I have an 06 all stock banshee and do alot of dune riding along with some drag racing and some trail riding out there but not too much. I am looking to buy a good set of pipes along with an intake and some reeds. Any suggestions? Oh and money not too much of a problem. Quote
Bansh-eman Posted January 15, 2008 Report Posted January 15, 2008 use the search botton, you will find all the info you could possibly want to know for a stock motor Quote
BigRed350x Posted January 15, 2008 Report Posted January 15, 2008 I agree, use the search. But if you do dune riding, trails and drag racing I would go with the T5's for pipes. VForce 3's and a set of billet aluminum intakes with the rubber boot you can change out. Trinity, Boss, K&T, all kinds of people make them. Step up to some 33mm carbs for a stock motor and you will be set. Advance your timing by modding the stock plate or buying an aftermarket one. Get a cool head of some sort if you don't have one yet. Basic stock bike mods... cool head advance timing reeds pipes intakes and carbs K&N pod filters for above carbs. then do some porting to really wake it up. Quote
fastquad02blaster Posted January 16, 2008 Report Posted January 16, 2008 When you advance the timing, Is there any problem with running premium pump gas? About how many degrees does it advance it? Quote
BigRed350x Posted January 16, 2008 Report Posted January 16, 2008 When you advance the timing, Is there any problem with running premium pump gas? About how many degrees does it advance it? 4 degrees is good on a stock bike. Ability to run different gas depends on altitude, compression, squish, blah blah blah... do a search. Quote
theshee Posted January 16, 2008 Report Posted January 16, 2008 T-5s, timing plate +4 degrees, Vforce 3 reeds, pod filters and a coolhead. Boom, done deal. :thumbsup: Quote
RagunCajun Posted January 16, 2008 Report Posted January 16, 2008 i have stock carbs and even with my port job, works fine. Quote
bansh03 Posted January 17, 2008 Report Posted January 17, 2008 i have stock carbs and even with my port job, works fine. Same here, runs GOOD! Quote
wacko2000 Posted January 17, 2008 Report Posted January 17, 2008 Im also rocking stock carbs with my port and some other stuff and the bike rips.... I have T5's and I think they are great... pipes-reeds-compression bump-timing advance- and a good filter and you will have a totally different machine.. My timing is advanced +4, I run 93 and Its all good. Quote
rubberneck Posted January 17, 2008 Report Posted January 17, 2008 Ditto on the above. I have 2 shees. Both T5's, Vforce reeds, +4 timing. One has K&N pods, the other UNI stock replacement. Soon both to have cool heads with 20cc domes. You will not believe it is the same bike. Quote
F.BEJARANO Posted January 17, 2008 Author Report Posted January 17, 2008 Ditto on the above. I have 2 shees. Both T5's, Vforce reeds, +4 timing. One has K&N pods, the other UNI stock replacement. Soon both to have cool heads with 20cc domes. You will not believe it is the same bike. So, Im debating on getting a pro design with k&n filter and just removing the air lid or pods. What do you guys think Quote
rubberneck Posted January 17, 2008 Report Posted January 17, 2008 Totally depends on where you ride. If all you do is sand get the pods. If you ever ride mud/wet areas, keep the box and do the prodesign. Quote
fastquad02blaster Posted January 26, 2008 Report Posted January 26, 2008 Totally depends on where you ride. If all you do is sand get the pods. If you ever ride mud/wet areas, keep the box and do the prodesign. Does the tors eliminator give any more power? Quote
HotCarl Posted January 26, 2008 Report Posted January 26, 2008 Does the tors eliminator give any more power? No it just changes the carb tops and the idle screw to something that isn't going to fail. Quote
