how long are your swingarms on your 10 mills ?
kawi- I ran a +10 swinger with a +8 extended frame on my 10 mil last year.
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
brad i believe your 10mil is the hardest running cub motor i have seen run yet in person.
Thanks. Its getting there. Now if I could get it to hook and stay hooked.
making some chassi changes hopefully it works.
  • 2 weeks later...
I am a prime example I had an idea that it would cost me around $3500 to build a 521 . It cost me almost $5000 and I ran out of money before I could do the suspension im running a +6 (multi purpose quad tell I buy a trail rig) swinger 39 pwks big bowls 10mm super cub , cpi big bore inframes rdz head .If I had it to do again I would count on money for the right paddles and good shocks. and make sure when you buy your cub is ported first otherwise you are looking at reniking it later
I disagree...they run fine right out of the box. However, they should be cleaned up...the casting flaws on some are worse than others.
Mine wasn't too bad. I spent probably an hour or two cleaning up and smoothing the intakes and transfers were the casting halves meet.
Cleaned up is all you need. For 5 grand, hell...you could've bought a bike completely done, bumper to bumper, spark plug to drain plug....
  • 3 weeks later...
