wacko2000 Posted December 6, 2007 Report Posted December 6, 2007 I need to know what size drill bit it will take to turn my stock pilot to a 27.5 I am goin riding this weekend, Im currently running a 30, and its to fat, none of the shops around me stock these and wont have them until next week.. anyone have any ides for me to try, I have no use for the 25 so It cant hurt to drill it out for know until the 27.5 comes in some time next week... Quote
RIPRuck Posted December 6, 2007 Report Posted December 6, 2007 Why didnt you just have them sent priority mail? I'm sure Jeff has them and he'll next day ship to you! I needed a certain needle (which was hard to find) for my single to go riding that comming weekend which was 2 days later, called up Jeff paid a little extra and had them the next day.. Quote
wacko2000 Posted December 6, 2007 Author Report Posted December 6, 2007 yea thats doesnt sound like a bad idea, but i ordered them for the local stealership already, I will call him tom i dont mind eating the 10 that i gave the stearlership.. It cant be that hard to drill them though, i kno that there was a shop by me that used to do it , they drilled my brother 250 for him.. Quote
brian Posted December 6, 2007 Report Posted December 6, 2007 Those pilots have really tiny holes in em. Even if you could find out the size, the drill that size wouldn't be found in a standard drill index. You would have to try to find one elsewhere. It would probably take more time to find the drill than it would to get the proper jet from FAST. Also, it wouldn't be as easy as drilling out a main jet. If you are not perfectly steady you'll break that size drill really easily. Just my opinion, but modifying a pilot would prove to be more trouble than it's worth. Quote
riderofthestorm Posted December 6, 2007 Report Posted December 6, 2007 I need to know what size drill bit it will take to turn my stock pilot to a 27.5I am goin riding this weekend, Im currently running a 30, and its to fat, none of the shops around me stock these and wont have them until next week.. anyone have any ides for me to try, I have no use for the 25 so It cant hurt to drill it out for know until the 27.5 comes in some time next week... well, if you have the 25 and the 30 jets, and you have bits that fit them,, just find the bit thats in between them and it should work till you get your new 27.5, might not be exact but who knows it might be better! lol good luck Quote
wacko2000 Posted December 6, 2007 Author Report Posted December 6, 2007 Yea thats what I was thinkin, cant hurt to try, whats the worse that could happen, Im buying the 27.5 anyway.. Yea I have tons of drill bits.. anways Ill keep you;s posted with the results... Quote
riderofthestorm Posted December 6, 2007 Report Posted December 6, 2007 Yea thats what I was thinkin, cant hurt to try, whats the worse that could happen, Im buying the 27.5 anyway..Yea I have tons of drill bits.. anways Ill keep you;s posted with the results... yeah man, let us know how it turns out, Quote
Lepew Posted December 6, 2007 Report Posted December 6, 2007 Yea thats what I was thinkin, cant hurt to try, whats the worse that could happen, Im buying the 27.5 anyway..Yea I have tons of drill bits.. anways Ill keep you;s posted with the results... When you drill them grind off the jet number, you don't want a jet marked with the wrong size. Quote
dajogejr Posted December 6, 2007 Report Posted December 6, 2007 As said on the E2S. Either leave the 30s in and turn your air screws to 2.5 turns out, or put stockers back in and turn the air screws .5 turns out. People drill main jets for methanol because you drill them from .110 to .125. Easily found in a drill index... You'd probably need a .00 something for the pilots...and when it's all said and done, how do you know you're not going to plug the small holes on the outside... You're going to ruin your weekend of riding by taking this chance? Use the air screws.... Quote
badassbanshee479 Posted December 6, 2007 Report Posted December 6, 2007 yeah.. dont drill it... screw it. :biggrin: sorry could not resist Quote
wacko2000 Posted December 6, 2007 Author Report Posted December 6, 2007 (edited) Okay I need some help.. played with the pilot and air screw today, I left the 30 in there, I started at .5 out and work my way out, at .5 it was smoking alot, as I turned it out .5 at a time the bike got louder It ran the best at 2-3 turns out but it stop smoking and when i put my hand byt the pipes there wasnt much pressure comin out.... some help please? Also I did the carb trick, I pulled the choke out half way, and rode it, It got worse doesnt that mean that I am to rich on the pilot and it would be safe to lean it out? Edited December 6, 2007 by wacko2000 Quote
LiftdT4R Posted December 6, 2007 Report Posted December 6, 2007 Sounds right, as you turn the screw out, your leaning out the pilot mixture. With that big 30 jet your gonna wanna be somewhere in the neighborhood of 2.5 to 3 turns out if your still running the stock box with a lid. Quote
wacko2000 Posted December 7, 2007 Author Report Posted December 7, 2007 Im still running the stock air box but, No lid Right know I have it set at 2.5 out, but I was alittle nervous bc shee was barely smoking, dont know it thats okay or not... Quote
brian Posted December 7, 2007 Report Posted December 7, 2007 (edited) keep in mind that you are only dealing with the low speed circuit here. idle to 1/8th throttle. you dont need to worry about burning up the motor from being too lean at this range. it wont act right if you are too far off. just adjust the air screw until it idles right and comes off and returns to idle smoothly. then it will be set right. it is not required to smoke to be running properly. that depends alot on the amount and type of premix oil you use. mine usually only smokes (very little) when it is cold. when it warms up there is almost never any smoke. Edited December 7, 2007 by brian Quote
wacko2000 Posted December 7, 2007 Author Report Posted December 7, 2007 keep in mind that you are only dealing with the low speed circuit here. idle to 1/8th throttle.you dont need to worry about burning up the motor from being too lean at this range. it wont act right if you are too far off. just adjust the air screw until it idles right and comes off and returns to idle smoothly. then it will be set right. it is not required to smoke to be running properly. that depends alot on the amount and type of premix oil you use. mine usually only smokes (very little) when it is cold. when it warms up there is almost never any smoke. thanks man you answered my next question, I was concerned about burning up my motor if the pilot was to lean... im goin to leave the 30 in there for know and see if I can find a sweat spot, If not i will through the 25 in there and start over... Quote
