robmoney Posted December 6, 2007 Report Posted December 6, 2007 I purchased a 2001 banshee, all stock. Checked everything out, test drove...everything checked out good. I noticed Neutral was a bit hard to find, but easier when it was shut off. I havent had a chance to ride it good since I purchased it. Mainly a couple putts around the backyard. I jumped on it tonight and noticed I only had 1st and 2nd gear. More smoke than usual, there is a slight knock on tranny side, and the oil is a little low (light grey in color) Im a novice when it comes to repair, espically since this is my first banshee What should I look for? I searched the forum and found things similar but nothing the same as what Im experiencing. Quote
jaredvh Posted December 6, 2007 Report Posted December 6, 2007 (edited) I purchased a 2001 banshee, all stock. Checked everything out, test drove...everything checked out good. I noticed Neutral was a bit hard to find, but easier when it was shut off. I havent had a chance to ride it good since I purchased it. Mainly a couple putts around the backyard. I jumped on it tonight and noticed I only had 1st and 2nd gear. More smoke than usual, there is a slight knock on tranny side, and the oil is a little low (light grey in color) Im a novice when it comes to repair, espically since this is my first banshee What should I look for? I searched the forum and found things similar but nothing the same as what Im experiencing. I have the exact same problem on my 1994 banshee... i thought my tranny was maybe going but i dont know much about banshees. oh but i still have all my gears... Edited December 6, 2007 by jaredvh Quote
chevrolet banshee Posted December 6, 2007 Report Posted December 6, 2007 I purchased a 2001 banshee, all stock. Checked everything out, test drove...everything checked out good. I noticed Neutral was a bit hard to find, but easier when it was shut off. I havent had a chance to ride it good since I purchased it. Mainly a couple putts around the backyard. I jumped on it tonight and noticed I only had 1st and 2nd gear. More smoke than usual, there is a slight knock on tranny side, and the oil is a little low (light grey in color) Im a novice when it comes to repair, espically since this is my first banshee What should I look for? I searched the forum and found things similar but nothing the same as what Im experiencing. I have the exact same problem on my 1994 banshee... i thought my tranny was maybe going but i dont know much about banshees. oh but i still have all my gears... Ok so i just went threw the same problem. my banshee only had 2-3-4 gears tho so i tuck off the clutch cover and the clutch. then i pulled the little thing that keeps the shift hub in one place off. after that i played with the shift star a little bit till it freed up. i think that i have a bent shift fork so i will replace that. Quote
Screaming Yellow Zonker Posted December 6, 2007 Report Posted December 6, 2007 can you shift through the gears with the engine off? if no you could have a bent shift fork, or damaged shift "dog" or barrel. is the fluid sparkley like gears or dull like clutch material? all banshees have a problem finding neutral. Quote
robmoney Posted December 6, 2007 Author Report Posted December 6, 2007 I played with it a little bit, I didnt remove the cover, but I have all gears, it seems as though it "skips" gears when shifting. The clutch doesnt slip or anything. My fiances cousin is coming over to look at it tomorrow, but I wanted to get familiarized with certain errors before he comes over. Quote
