Why are you not using some sort of surfactent in there in the summer? :confused:
Take your engineering hat off and explain to me what surfactent means....
Is that even a word? LOL...
Water is what we ALL run around here. If you pop an oring, you can do more damage to your head by sucking coolant than you can sucking water.
Just use the root words...
surf - act - ent
surf = of the sea
action = a thing done
enter = to go into
surfactent = put salt water in your radiator! :thumbsup:
I was just playin with Mark....
Water straight out the tap works fine...alky runs cool enough, water does the job fine!!
Plus..any asphalt tracks won't let you run antifreeze, it's straight water only I'm pretty sure, depending on how picky they are for tech inspection.
oh.. :smile: But thats Detroit tap water.. so there has to be some sort of additive in there somwhere!
Edited by Fouledout421
Surfactants, also known as tensides, are wetting agents that lower the surface tension of a liquid, allowing easier spreading, and lower the interfacial tension between two liquids. (I copied than from Wikipedia. It should be also noted that I spell surfactant wrong in my previous post.) :geek:
Water Wetter (and similair products) is let pass at almost all racing facilities. :thumbsup:
......................and Detroit smells bad. :biggrin:
so do those pirate hooker you brought to my house!
dave the only thing with tap water is there is alot of minerals that can collect to the inside fins and gum up your rad. thats why you should run distilled
Just a word of warning, I also used the Home depot / Lowes clear hoses with nylon strings, and they worked great for about 3 years. Then, the shee must have got a little hot, becuase one line blew all over my leg, and burned me a little bit. Needless to say, they got replaced with the ALBA ones.
3 years inst bad for 4 dollars on the hoses though
