i tore into my first engine to rebuild last month.. im soon goign to be putting it all back togther.. prolly by the end of this week. im looking for some advice on rebuilding this shee engine.. got any tecniques? is there any stubborn things to watch out for with these banshees? is there any things i have to do to make sure things go right? ive had some questions along the way but most have been answered.. thanks to BHQ. please help me out with things to watch for.
Edited by flattrakker
I did it for the first time in may i think. I just fallowed the clymer manual and it was fine. Just take your time. First time takes the longest because it's all new to you.
the thing thats taking me the longest is making the decisions.. im 14 years old so idk if i can afford to port.. or should i lighten my flywheel.. you know? should be back together soon tho.. im ordering my final things tonight and they should be here by friday.
if you got the jugs off, i would get them ported while you can
im just trying to get it running before winter falls on me soon. i ride all winter every day so thats why.. im planning on getting some cheeta cubs in the future and ill get them drag ported.
  • 3 weeks later...
i would say an important thing to watch is when installing the cylinder (when u slide the piston into the jug) make sure your ring gaps arewhere they should be(locater pins in the rings grooves of the piston) .. also double check your circlips to make sure they are seated, its catastrophe if one comes out.. hope this helps..
get ring gap checked, put a little 2stroke oil on the gaskets to help seal, put a little 2stroke oil on the crank, dip your finger in 2stroke oil and smere it all around on the cylinders make sure you snug them cylinders down doing the criss cross pattern and most importantly! TAKE YOUR TIME! i messed up once on the blaster rushing to get it back together and i ended up installing the piston backwards which left me mind puzzled! untill i ripped it back apart for the 3rd time!
